Using craft paint with airbrushes
Has anyone had experience using craft paints (FolkArt, or Apple Barrel) in airbrushes? . I have a Paasche double action, internal mix brush, and want to use craft paints for priming, and base coating.
Is there a "set" formula for mixing the paint?
Any help is appreciated.
Runepriest
https://bolterandchainsword.com/topic/224085-using-craft-paint-with-airbrushes/
They go through an airbrush just fine, I haven't used them for minis though. There is no set formula but thin them to "milk", so less watery than actual water, but still flowy. 60:40 paint:water seems to work for me. I would recommend liquitex flow-aid also. Mix it 1:20 flow aid:distilled water and use that to thin your paint, not tap water.
Hope that helps you a little, I've only had my airbrush about a month but it is awesome.
