Blast markers and vehicles
An issue came up last game with my vindicator firing at my opponents wave serpent. DUe to scattering the centre of the template was only partically on the wave serpent his engine. My opponent argued that since the hole of the blast marker wasn't conpletely covering the vehicle I only hit at half strength. I wasn't in the mood for arguing, so I let it slide. But I wanted to check anyway.
In the samll rulebook on page 60 under 'Template and blast weapons against vehicles' their are 2 cases:
1. The centre of the blast marker ensd over the vehicle's hull -> hit at full strength
2. The centre of the blast marker ensd outside the vehicle, but part of the marker ccovers its hull -> hit at half strength.
Nowhere is stated that the centre has to be entirely over the vehicle's hull, this in my eyes my opponent was wrong and I should have had a S10 hit on his vehicle. What are your opinions on this?
https://bolterandchainsword.com/topic/224101-blast-markers-and-vehicles/
Firstly, I think you did very well to measure scatter so precisely that this was an issue! :)
To be honest, and it is a bit of a rubbish answer, this is probably a situation where you need to roll off for it. Measuring scatter is very imprecise anyway, and I expect GW assumed that the little hole in the template would be small enough that such problems would be unlikely to present themselves.
Actually, the hole has nothing to do with it. The line reads:
"The center of the blast marker ends over the vehicle's hull."
This means the exact center, as it doesn't say:
"The hole of the blast marker ends over the vehicle's hull."
So, only if the exact pinpoint center of the entire marker lands on the vehicle do you get a full strength shell. Otherwise, it's half strength. Both players were incorrect :)
well, to me the centre of the blast marker is the hole, but I guess it is rather open to opinion...
More accurately (and more to Seahawk's point), the center of the blast marker is the center of the hole at it's center...not the hole itself. :P The center is a point; the hole is not a point...it's a circle itself.
What Seahawk is saying is the centre is the very centre point of the circle, not the hole.
However, the rulebook rather unhelpfully switches between using the term 'hole' and 'centre', and sometimes 'hole in the centre'. So what are we supposed to use?
This seems to be another case of wordfail.
Perhaps it's best to treat the geometric centre of the blast markers as the key point as that is at least a fixed and determinable point upon which both players can agree.
Given how easy-going they seem to be about the rules, I bet they feel if any point of the center hole is over the vehicle, that counts as a full-strength hit. But it's not written that way, and at a Hardboyz Tournament you'd be hard-pressed to find any player that doesn't go by the center of the center hole for this call.
the centre of the centre of the hole? ok I can see that, and admit that my conclusion may not have been the correct one, personally I think that "any part of the centre hole" makes for easier friendly playing (all ready discuss enough with my friend's over models being seen and cover due to true line of sight, dont need something else to argue about), but when playing vs people I dont know I shall be sure to discuss this with them, I hope :P
So, only if the exact pinpoint center of the entire marker lands on the vehicle do you get a full strength shell. Otherwise, it's half strength. Both players were incorrect :P
^ this!!!
Actually, practically speaking, this is probably the easiest way to go, correct or not.
Seconded, and typically how I've seen it played at any friendly table I've been at.
Thirded. I've ALWAYS done this and everyone I've ever played does the same.
Fourthed.
Imagine the hole in the center as the actually projectile and the rest of the marker as the blast it creates upon impact. Use the very very center when your firing a "blast laser"
