Seahawk Posted March 16, 2011 Share Posted March 16, 2011 I need to weight some bases, but don't think I have the proper material handy. Where do you guys get scrap to weigh down your bases? Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/ Share on other sites More sharing options...
Keyboard Posted March 16, 2011 Share Posted March 16, 2011 You could try putting some 5 cents under the bases ^_^ Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2690369 Share on other sites More sharing options...
Seahawk Posted March 16, 2011 Author Share Posted March 16, 2011 Haha, well as these are slotta bases, I'd have to cut my money in half. That's certainly not in the plans! ^_^ Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2690372 Share on other sites More sharing options...
Durus Posted March 16, 2011 Share Posted March 16, 2011 Instead of money I'd glue washers under the bases. So some small nuts (as in bolt nut or screw-nut) might fit under a slotta base. Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2690392 Share on other sites More sharing options...
Seahawk Posted March 16, 2011 Author Share Posted March 16, 2011 Hmm, they'd have to be really small, but I'll check the hardware store this afternoon and see if there's anything. Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2690847 Share on other sites More sharing options...
Tanhausen Posted March 16, 2011 Share Posted March 16, 2011 Or small pieces of stones. Â Or if you have a fishing store close by, get some leads :) Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2690857 Share on other sites More sharing options...
ShinyRhino Posted March 16, 2011 Share Posted March 16, 2011 I clip small brad nails and glue them under the base. Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2690877 Share on other sites More sharing options...
Seahawk Posted March 16, 2011 Author Share Posted March 16, 2011 Pfft, I live in the vastness of cornfields. Ain't naw fishin' shops 'round these parts!  So far I've got:  - nickels - nuts - tiny stone - fishing leads - brad nail heads  I'm looking for tiny (because of the slottas), cost effective (as there are a lot of them I need to do), and most efficient (high density), so that rules out stone for the metals. I think I'll try this list this week and go from there. Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2690885 Share on other sites More sharing options...
Tanhausen Posted March 16, 2011 Share Posted March 16, 2011 You can always use GS... which is quite heavy. Â Or simply staple the base to the board and when you move the model, remove the staple, move, staple again... Â Also the stones... you can put them on top of the base... you know, texturizing and so on. Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2690894 Share on other sites More sharing options...
Seahawk Posted March 16, 2011 Author Share Posted March 16, 2011 Hmm, more food for thought... Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2690895 Share on other sites More sharing options...
Hexenes Posted March 17, 2011 Share Posted March 17, 2011 I recommend the lead fishing weights. They're really cheap and they're soft enough to cut with a modeling knife. Of course you have to exercise caution when handling them because they're lead, but once they're glued on, I paint them with a couple thick coats of paint to cover, and "Voila!", successfully doubled the weight of a standard plastic mini and made it bottom heavy so it doesn't topple over. Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2691550 Share on other sites More sharing options...
Chaplain Invictus Posted March 17, 2011 Share Posted March 17, 2011 Old metal scrap from metal models. I have collected a couple pounds of it, and a year or so ago, I did a plaster mould of the small and medium sized bases. Using the scrap pewter, I made full on pewter bases by pouring the hot metal into the mould I made from plaster. I only got like 6-7 bases per plaster mould before they cracked, but hey, not shabby for stuff I had lying around. Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2691555 Share on other sites More sharing options...
averykess Posted March 27, 2011 Share Posted March 27, 2011 I usually use pennies cut in half on the slottabases. I did my entire set of Genestealers from 2nd edition Space Hulk that way. Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2702484 Share on other sites More sharing options...
Olis Posted March 27, 2011 Share Posted March 27, 2011 Use big chunks of flash if you have nothing else to hand - always keep bits you thought you'd never need. Hell, spare resin chunks from my purchases have been chopped into itty bitty pieces and now live in my sandbox! :) Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2702564 Share on other sites More sharing options...
Ironwulf Posted March 27, 2011 Share Posted March 27, 2011 If you want to spend money on some weights, Impact Miniatures has some Pewter Base Weights, made specifically to fit GW-style slottabases. I've purchased some items from Impact before, and they seem like a nice group. Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2702741 Share on other sites More sharing options...
MagicMan Posted March 27, 2011 Share Posted March 27, 2011 Ive got a bunch of 1p's glued to the bottom of my Hormagaunt/Flying Chaplain bases. Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2702813 Share on other sites More sharing options...
Aki27 Posted March 27, 2011 Share Posted March 27, 2011 I fill my slotta bases with the tabs from the metal miniatures. Link to comment https://bolterandchainsword.com/topic/224901-scrap-metal/#findComment-2702826 Share on other sites More sharing options...
