Blackwyvern Posted March 18, 2011 Share Posted March 18, 2011 Ok I am going to try this just as a laugh and it is not to be taken seriously. I will write the first peice of the story then you post a rough out line for what happens next and I write it. the way I will pick is i will choose the first post with and idea that cames up. So here is the intro. The space marine scouts crept along the dark dank corridors of the desolate space hulk. "Squad move out" said Sergeant Detrion. Sintrio and Damon heade to the left fork at the split in the tunnel. suddelny they heard something rattling against the metal of the deck plates. as they turned the corners they suddelny saw... Ok now you decide what happens next. Link to comment https://bolterandchainsword.com/topic/225099-into-the-dark/ Share on other sites More sharing options...
AngelisMortis24 Posted March 31, 2011 Share Posted March 31, 2011 an ancient servitor but as they relax slightly they spot something flash past the end of the tunnel Link to comment https://bolterandchainsword.com/topic/225099-into-the-dark/#findComment-2708317 Share on other sites More sharing options...
Regem Nox Posted June 21, 2011 Share Posted June 21, 2011 a hive tyrant, they all died. the end. Link to comment https://bolterandchainsword.com/topic/225099-into-the-dark/#findComment-2798805 Share on other sites More sharing options...
