maverike_prime Posted March 20, 2011 Share Posted March 20, 2011 Greetings to all. I welcome to what is quickly becoming a regular event on the Bolter and Chainsword forums, Maverike Prime's Conversion Challenge. We've tried this a number of different ways and each version brings new obstacles to overcome. In our first challenge, we did a required Part. Beyond the required part being used in the conversion and being identifiable in the finished conversion, participants were free to do as they pleased for the challenge. The Required part was the Chronus Torso. The second challenge we did we used the main part of Lysander as the required part. With the third Challenge we changed things around and made it a "Counts as" challenge. In this case particapants were challenged to make a Counts as Mephiston. WarInHeaven took over the next challenge and issued a challenge to Update an older model to stand along side the newer releases. Finally I returned to run the last challenge, a Counts as Azreal. Now I am here to issue you a new challenge. With that, Welcome to Maverike Prime's Conversion Challenge #6! This challenge will be similar to the "Counts As" Challenges of the past, but this time I will provide a set of stats and rules. You must build a model to meet those stats. There is no required part, but I do ask you be prepared to justify or explain how your model meets the stat line. If I provide a list of stats that includes Front Armor: 12 and you provide a tactical marine, I ask that you explain why it counts as having armor 12. Challenge Stats WS BS S I A F.ARM S.ARM R.ARM 44642121210 WEAPONS: Heavy Machine cannon, either extreme rate of fire version, or heavy armor penetration version. Melee Combat Attachment. Medium Machine gun. Note: I have deliberately not used names like "Auto Cannon" "Bolter" or"Bolt gun" in the description to open the challenge up and promote creativity. For those of you who are new to this challenge, and want to know more about it, here is some information. If you have any additional question after reading this information, please post them in this thread: Interested in a conversion challenge? Rules and Information for the Challenge: What is this Conversion Challenge? This conversion Challenge will be a 1 month challenge where in each participant will create a converted model within the guide lines set down for the challenge. In this challenge, the guide lines are to represent a particular character. The Challenge is recorded has having started Sunday the 20th of March, at 12pm eastern time. All entries MUST be submitted prior the end time of April 20th, 12pm eastern time. There will be NO EXCEPTIONS! Limitation 1: The conversion must be appropriate for this forum (Remember, we are on BolterandChainsword.com after all) Limitation 2: All submissions should be based on game appropriate bases, 40mm base or 60mm base are appropriate . Try to avoid putting the conversion on bases larger then 60mm. Those are the only limitations. When is this Challenge? The Challenge began Sunday the 20th of March, at 12pm eastern time. The challenge will run until April 20th, 12pm eastern time. By April 20th, 12pm eastern time, ALL entries must be in. How do I submit my conversion? Post pics of it. There are several free image hosting services available online including Photobucket and Flickr. You can upload your pictures to those services and then post links to them in a thread on this forum. If you encounter difficulty in getting the pictures uploaded, I encourage you to ask for help. For additional information on taking good pictures of your miniature, We suggest you take a look at the B&C's Photoshop Tutorial: Profession Pics of your Minis. What do I need to submit? Pictures. for simplicity sake, I ask that you submit 5 shots of your conversion. 1) Front or head on shot 2) A shot from the left side 3) A Shot from the right side 4) A shot from the back side 5) A 3-view shot from the front-right, or front-left. You're choice. Here are Examples of Each shot: head on shot http://i14.photobucket.com/albums/a316/maverike_prime/Warhammer/head-on.jpg The Camera is looking directly at the model and the model is facing right toward the camera. Left Side shot http://i14.photobucket.com/albums/a316/maverike_prime/Warhammer/left-side.jpg The Camera is looking directly at the model and the model is facing To the left edge of the frame. This helps give the judges a sence of the depth of the model. What may look like a flowing cloak from the front, could be shown to be a flat panel from the side Back shot http://i14.photobucket.com/albums/a316/maverike_prime/Warhammer/back-shot.jpg The Camera is looking directly at the model and the model is facing directly away from the camera. Right Side http://i14.photobucket.com/albums/a316/maverike_prime/Warhammer/right-side.jpg The Camera is looking directly at the model and the model is facing To the right edge of the frame. This helps give the judges a sence of the depth of the model. What may look like a flowing cloak from the front, could be shown to be a flat panel from the side. 3-view http://i14.photobucket.com/albums/a316/maverike_prime/Warhammer/3-view.jpg This is the "Damn! Does this guy look hawt!" shot. It also helps give the judges a better sence of the model as a whole. if the judges need a different shot of your conversion, we will contact you and ask for a specific shot. Where do I send the pictures? On this forum. Submit a post in this thread. What about painting? As already stated, this is a Conversion contest. Not a Golden Daemon or Golden Bolter. You will receive no extra credit for a good paint job. In truth, painting your conversion before we announce the winners will probably hurt your chances at winning as painting tends to hides a conversion. Check out the prior challenges: Challenge 1 – Kronus’ Torso Challenge 2- Lysanders Body Challenge 3- Character Challange: Mephiston Challenge 4- Revamping an Old Model (Run by WarInHaven) Challenge 5- Character Challenge: Azreal Link to comment Share on other sites More sharing options...
Terminatorinhell Posted March 20, 2011 Share Posted March 20, 2011 Mini guns and other generic massive weapons? count me in! Link to comment Share on other sites More sharing options...
smallvictory Posted March 20, 2011 Share Posted March 20, 2011 Woah, a vehicle! Nice curveball. I need to make a dread for my army anyways, now how to make it super cool in ways that crush the compitition.............. Link to comment Share on other sites More sharing options...
maverike_prime Posted March 21, 2011 Author Share Posted March 21, 2011 Want to keep this on the front page while people can still submit entries for it. Link to comment Share on other sites More sharing options...
IronfrontAlex Posted March 21, 2011 Share Posted March 21, 2011 Count me in! Link to comment Share on other sites More sharing options...
maverike_prime Posted March 21, 2011 Author Share Posted March 21, 2011 Count me in! You are counted. Now just make sure you make a submission other wise you will count for nothing in regards to the challenge. Link to comment Share on other sites More sharing options...
Brother Styphus Posted March 22, 2011 Share Posted March 22, 2011 Thread might need quite a few bumps this week, what with the LPC coming to an end. Link to comment Share on other sites More sharing options...
Terminatorinhell Posted March 23, 2011 Share Posted March 23, 2011 Speaking of which... *bleep* I still have to do my LRR.... grumble grumble... Link to comment Share on other sites More sharing options...
GooseDaMoose Posted March 23, 2011 Share Posted March 23, 2011 You know, as far as I've seen, people don't start submitting their entries until towards the end of the challenge.. Do you intend to keep bumping this until the 20th April so people can find it to submit it, or are you bumping it so more people see there's a challenge? Link to comment Share on other sites More sharing options...
maverike_prime Posted March 23, 2011 Author Share Posted March 23, 2011 You know, as far as I've seen, people don't start submitting their entries until towards the end of the challenge.. Do you intend to keep bumping this until the 20th April so people can find it to submit it, or are you bumping it so more people see there's a challenge? the later. Link to comment Share on other sites More sharing options...
Madcap Posted March 24, 2011 Share Posted March 24, 2011 Point of clarification: you did not indicate the model type. As it has a WS, S and Armor, are we to assume it's a walker? Or can I convert a daemonic possesses skimmer with those stats? Link to comment Share on other sites More sharing options...
maverike_prime Posted March 24, 2011 Author Share Posted March 24, 2011 Point of clarification: you did not indicate the model type. As it has a WS, S and Armor, are we to assume it's a walker? Or can I convert a daemonic possesses skimmer with those stats? There is no required model type. You may make what ever you want, so long as you can explain how your model meets those stats. Link to comment Share on other sites More sharing options...
smallvictory Posted April 7, 2011 Share Posted April 7, 2011 Sorry bro, got a little distracted, I'm back on it tonight, gimme a week. Link to comment Share on other sites More sharing options...
Stroganoff Posted April 10, 2011 Share Posted April 10, 2011 This challenge sounds right up my alley, but I was wondering are scratch builds allowed? Or does there need to be some form of base GW part? Link to comment Share on other sites More sharing options...
maverike_prime Posted April 10, 2011 Author Share Posted April 10, 2011 This challenge sounds right up my alley, but I was wondering are scratch builds allowed? Or does there need to be some form of base GW part? Scratch build is fine. Link to comment Share on other sites More sharing options...
maverike_prime Posted April 11, 2011 Author Share Posted April 11, 2011 What? No one yet? only 10 days left. Link to comment Share on other sites More sharing options...
maverike_prime Posted April 13, 2011 Author Share Posted April 13, 2011 Come on guys. 7 days left. Link to comment Share on other sites More sharing options...
maverike_prime Posted April 14, 2011 Author Share Posted April 14, 2011 6 days Link to comment Share on other sites More sharing options...
Zealot Of Chaos Posted April 14, 2011 Share Posted April 14, 2011 Entry! here we go, as you can see he perfectly fits all the requirements and all coming in at around the height of a space marine knee. I'll take that banner now because no one else has entered yet :) (please note that this post is meant in good jest and is not a slander on the Bolter and Chainsword or Maverike Primes conversion competition ++EDIT++ Although the image does go against the grain of what we allow here (Ie it is clearly non PA themed), i'll allow it solely for the purpose of the challenge, however I do expect next time everyone will remember to take the board rules into consideration. Link to comment Share on other sites More sharing options...
maverike_prime Posted April 15, 2011 Author Share Posted April 15, 2011 Zealot... if you can give me a justification as to how that Gretchen rates Strength 6, with Front and side armor of 12, I will give you the banner on account of sheer creativity. Link to comment Share on other sites More sharing options...
DV8 Posted April 15, 2011 Share Posted April 15, 2011 He's the Hulk, pre-emo-rage. The angrier he gets, the bigger/stronger he gets. He is green after all... DV8 Link to comment Share on other sites More sharing options...
maverike_prime Posted April 15, 2011 Author Share Posted April 15, 2011 He's the Hulk, pre-emo-rage. The angrier he gets, the bigger/stronger he gets. He is green after all... DV8 That covers the S6. And I'll even give him T6. But AV: 12? Link to comment Share on other sites More sharing options...
Zealot Of Chaos Posted April 15, 2011 Share Posted April 15, 2011 For the Str and Toughness I thank DV8 for He's the Hulk, pre-emo-rage. The angrier he gets, the bigger/stronger he gets. He is green after all... Armour... Have you seen that terrifying helmet and leather armour and leather shoes , it is widely known that Orc Hide is naturally tough, so much so that when cured and dried into a leather it can stop all small arms fire, its only weakness is the back of the Orc Hide armour as fearsome Gretchin do not need strong rear armour as the enemy is to their front and they shall not flee, its a lesser known fact that the only thing Darnath Lysander, Marneus Calgar, Commisar Yarrick, Ghazgull Thraka, the Nightbringer etc etc etc and Khorne fear is a Gretchin in Orc Hide Leather Armour, Gretchin Skull cap and a "So long and thanks for all the fish blaster", the only thing they fear more than a gretchin equipped this way is meeting 2. The only thing tougher than Orc Hide Armour is the feared and loathed Gretchin Skull Cap, made from the toughest material in the universe Gretchinskullcapium, it can only be refined to make gretchin skull caps as the machinery to accomplish just this task requires the resources of the Orc equivalent of a Forge World, therefore should anything bigger be created out of Gretchinskullcapium the facilities would be bigger than the planet it resides on; Gretchin skull caps have been known to survive direct Lascannon hits but only 1 in 3 times will the Gretchin go unhurt, 1 in 6 times he will be stunned or even incapacitated for a turn and 1 time in 2 the Gretchin will suffer some fatal damage only for the regiment he is in to fire at whosoever dared to kill a Gretchin killing the guilty party and anything else within a 2 mile radius to the front of the Gretchin. Link to comment Share on other sites More sharing options...
GooseDaMoose Posted April 15, 2011 Share Posted April 15, 2011 I say give this man his BANNER! Link to comment Share on other sites More sharing options...
Chapter Master Ignis Domus Posted April 16, 2011 Share Posted April 16, 2011 Plus his gun is so big compared to him, it should give him armor. Link to comment Share on other sites More sharing options...
