Zetzue Posted March 20, 2011 Share Posted March 20, 2011 Hmm i was planing on using a squad of VV for my list with. So how shall i run them with jump packs and deep strike and hope for a good roll on the reservs rolls or drop the jp and give them a drop pod and get them in first turn and use heroic intervention? ;) Link to comment Share on other sites More sharing options...
Cpt. Blood Donator Posted March 20, 2011 Share Posted March 20, 2011 They can only use H.I with jump packs. Link to comment Share on other sites More sharing options...
Mr.darkness Posted March 20, 2011 Share Posted March 20, 2011 I run a squad of ten to great effect. They have jump packs to use heroic intervention. I use them in conjunction with a drop podding dread. Even if the pod has a locator beacon people often tend to forget it when they have a multi melta toting dread at the rear of their lines! I would defo recommend at least 3 power weapons and 2 power fists, on top of the sergeants power weapon. That a means that you can combat squad them and have 2 PW and a PF in each squad. Link to comment Share on other sites More sharing options...
Zetzue Posted March 20, 2011 Author Share Posted March 20, 2011 I run a squad of ten to great effect. They have jump packs to use heroic intervention. I use them in conjunction with a drop podding dread. Even if the pod has a locator beacon people often tend to forget it when they have a multi melta toting dread at the rear of their lines!I would defo recommend at least 3 power weapons and 2 power fists, on top of the sergeants power weapon. That a means that you can combat squad them and have 2 PW and a PF in each squad. Â Â Alright that sounds awesome ! but when the arrive from deep strike with H I may the walk ? or can the only assault ? Link to comment Share on other sites More sharing options...
Cpt. Blood Donator Posted March 20, 2011 Share Posted March 20, 2011 The rule is pretty clear on what they can do. Charge, or nothing. If you H.I and are out of range, you may do nothing at all. Link to comment Share on other sites More sharing options...
Mr.darkness Posted March 20, 2011 Share Posted March 20, 2011 Yep that's the rule above.also remember that if you do combat squad them then you roll for thei reserves separately and they arrive separately. Link to comment Share on other sites More sharing options...
Gv0zD Posted March 20, 2011 Share Posted March 20, 2011 You declare HI, deploy them, and if in range you assault or nothing. Â As for VV loadout, there has been a thread, which you may find in Blood Angels Resource Project in the sticky ones here - there is a good discussion on this topic. Â In general, you may equip them anyway you see fit, anyway you like it, they are a very flexible unit. You may find numerous loadouts that worked well for many people. Just remember - 10 men squad loaded with PWs would cost you approx. 400 points. A bit expensive -_- Link to comment Share on other sites More sharing options...
Lord Fancy Pants Posted March 20, 2011 Share Posted March 20, 2011 Yep that's the rule above.also remember that if you do combat squad them then you roll for thei reserves separately and they arrive separately. Â That's actually not correct according to the new FAQ. You don't combat squad until you deploy from reserves, so you only make one roll for all ten to come on and have to deploy both squads at the same time. They can deploy in separate locations however. Link to comment Share on other sites More sharing options...
Zetzue Posted March 20, 2011 Author Share Posted March 20, 2011 ya the are expensive with full pw tho i wont run them with full pw no fun if the scatter ;P play alot agens eldar and he is no fun at all only uses ap 2 weps so i need to be careful with my 2 adn 3+ saves units becuse if the are out in combat he always kills halv of my units -.- have to take transports for everyting... Link to comment Share on other sites More sharing options...
Taz Posted March 22, 2011 Share Posted March 22, 2011 I've been thinking about making a VV squad composed of single LC's and SS, with the sarge toting a thunder hammer with SS for effect. Seems like the kind of thing that could take on or at least tarpit deathstar units and survive more than a round or two of combat. Link to comment Share on other sites More sharing options...
