Isryion Posted March 20, 2011 Share Posted March 20, 2011 Just wondering if any idea the parts that Terminator Armor would broken into when it's off. I ask because I'm working on a piece that basically an empty suit, but I've got no idea where or how to break it up. Link to comment https://bolterandchainsword.com/topic/225253-terminator-armor/ Share on other sites More sharing options...
cassar Posted March 20, 2011 Share Posted March 20, 2011 i would say from a practicle aproach the legs and hips would be somthing like putting on a pair of trousers then posiible the torso would be lowerd onto the pilot from above you would raise your arms above your head and place them throught the arm holes during this, once the torso is connected to the waist you would then set about putting on the arms. only my innitial thoughts in this regard youunderstand. Link to comment https://bolterandchainsword.com/topic/225253-terminator-armor/#findComment-2695564 Share on other sites More sharing options...
Iron Father Rik Posted March 20, 2011 Share Posted March 20, 2011 If you look at the models, they often have obvious panels on them which you can use as areas where different plates join. That and any area where there are obvious joins, like the shoulders, wrists, knees etc and other areas where there are armour plates raised higher than the surrounding plates. Link to comment https://bolterandchainsword.com/topic/225253-terminator-armor/#findComment-2695568 Share on other sites More sharing options...
Gv0zD Posted March 20, 2011 Share Posted March 20, 2011 IIRC there is a picture in Space Hulk book with servitors putting termie armor on a marine. I think in disassembled state the armor would be a pile of plates. If you want to get an idea of how it breaks up - look for disassembled medieval full plate. In fact TDA is its future version ;) Link to comment https://bolterandchainsword.com/topic/225253-terminator-armor/#findComment-2695601 Share on other sites More sharing options...
