Nassi Posted March 24, 2011 Share Posted March 24, 2011 I didnt have much luck with the search function, but i can almost guarantee this has been asked before. I recently found some old metal models, and figured with a bit of TLC they'd make nice additions to my current list; however, im not sure whats the best way to remove the thick layer of paint smeeared over them =( Any of your advice and tried + trusted methods would be greatly appreciated Nassi Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/ Share on other sites More sharing options...
Tanhausen Posted March 24, 2011 Share Posted March 24, 2011 If they are metal, any normal solvent (acetone or turpentine). If plastic, normal or even isopropyl alcohol. People also use (and here goes the list) Purple Power, Dot 3 brake fluid, Simple Green, oven cleaners and I'm sure I miss more thing... I use the two above. Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/#findComment-2699894 Share on other sites More sharing options...
crazychib Posted March 24, 2011 Share Posted March 24, 2011 Dettol or Mr Muscle Kitchen cleaner. Both work well on metal and/or plastic minis. Just soak for about 24hrs then rinse with water and scrub with an old toothbrush. Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/#findComment-2699939 Share on other sites More sharing options...
KJB Posted March 24, 2011 Share Posted March 24, 2011 I've been using Dettol - leave to soak for an hour or 2 and then scrub with an old toothbrush, the paint comes straight off - I've tried it on metal, plastic and Forge World resin parts and have had no issues (bar the headaches from not opening the window...) Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/#findComment-2699968 Share on other sites More sharing options...
AngryJohnny Posted March 24, 2011 Share Posted March 24, 2011 Here's a link to the Paint Stripping FAQ in the tutorials section. Personally I use Easy Off Oven cleaner. It works great for both plastic and metal miniatures with absolutely no damage to the plastics or metals. I haven't found a paint or primer it wont remove yet. BTW - Doesn't harm my FW Resin either. Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/#findComment-2699977 Share on other sites More sharing options...
Dorns Padawan Posted March 24, 2011 Share Posted March 24, 2011 Acetone free nail polish remover. Leave models (plastic or metal) to soak for approx 45-60 seconds then scrub them with an old tooth brush. Works really really well. Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/#findComment-2700302 Share on other sites More sharing options...
Olis Posted March 25, 2011 Share Posted March 25, 2011 Btw, B&Cers, when you use Dettol to strip models have a little Dettol set to one side to dip the mini in so you can swill paint clumps off (this is after the overnight soak, of course). IF YOU USE WATER THE PAINT CLUMPS WILL STICK TO THE MINI!! Once free from the Dettol dip THEN you can use water. And wear marigolds or something similar while you do this - neat Dettol is not skin friendly (it's no real biggie if you get some on your skin, just wash it off). If you disregard hand protection - don't say I didn't warn you. :P Recap: 1) Dettol soak the minis overnight 2) Scrub with an old brush (toothbrushes are good for this but they don't have a long shelf life due to clogs) 3) Dip the scrubee in a Dettol bath and wash off excess clumpage 4) Wash under a tap to get rid of excess Dettol That's it (I think). Given the amount of times I mentioned Dettol I reckon they should be paying me for this... :blush: Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/#findComment-2700676 Share on other sites More sharing options...
Nassi Posted March 25, 2011 Author Share Posted March 25, 2011 Btw, B&Cers, when you use Dettol to strip models have a little Dettol set to one side to dip the mini in so you can swill paint clumps off (this is after the overnight soak, of course). IF YOU USE WATER THE PAINT CLUMPS WILL STICK TO THE MINI!! Once free from the Dettol dip THEN you can use water. And wear marigolds or something similar while you do this - neat Dettol is not skin friendly (it's no real biggie if you get some on your skin, just wash it off). If you disregard hand protection - don't say I didn't warn you. :huh: Recap: 1) Dettol soak the minis overnight 2) Scrub with an old brush (toothbrushes are good for this but they don't have a long shelf life due to clogs) 3) Dip the scrubee in a Dettol bath and wash off excess clumpage 4) Wash under a tap to get rid of excess Dettol That's it (I think). Given the amount of times I mentioned Dettol I reckon they should be paying me for this... :ermm: Did you say to use dettol? :-s Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/#findComment-2700855 Share on other sites More sharing options...
Carmine_the_Wolf Posted March 25, 2011 Share Posted March 25, 2011 In the UK, use Fairy Power Spray...works a treat on both metal and plastic. Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/#findComment-2700991 Share on other sites More sharing options...
Olis Posted March 25, 2011 Share Posted March 25, 2011 Did you say to use dettol? :-s :sweat: Too much product placement? :rolleyes: Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/#findComment-2701224 Share on other sites More sharing options...
Emperors Immortals Posted March 27, 2011 Share Posted March 27, 2011 Dettol, but i swear by Methylated spirits - wont damage plastic or metal (ive scrubbed about 3000 pts worth so far) but it will turn resin in to water. Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/#findComment-2703140 Share on other sites More sharing options...
Master of fact Posted March 27, 2011 Share Posted March 27, 2011 fairy powerspray! for the win! Link to comment https://bolterandchainsword.com/topic/225557-removing-paint/#findComment-2703224 Share on other sites More sharing options...
