Dry rub off decal paper
Forté
Came across some dry rub Decal paper and was wondering if anyone has tried using it on miniatures? Looks like it would avoid having to use sprays and may be easier to position. Not sure how good it would work on curves like shoulder pads though.
Any thoughts?
https://bolterandchainsword.com/topic/225752-dry-rub-off-decal-paper/
When I was a kid, they'd add a sheet of these to the Paas Easter Egg kits. As I recall, they can look really good when you do them right, but just one little slip and you're hosed.
Seeing as they followed the curve of an easter egg pretty well, they should work just fine on shoulder pads...
Okay-- Thanks for the link. I honestly have NOT tried such a product. If you order some sheets of it, give it a shot on our behalf! I noticed that there are clear and white versions of the product, which might make a difference based on which Great Company insignia you attempt to put on the transfer, and the end result.
