Brother Constantine Posted March 26, 2011 Share Posted March 26, 2011 Hi guys! I am going to add a honour guard squad to my blood angels force. What wargear should I give them? Some people give them meltaguns, while others make them melee Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/ Share on other sites More sharing options...
Mr.darkness Posted March 26, 2011 Share Posted March 26, 2011 well, it really depends on what you need in your army. if you need a surefre way of killing a tank or two then give tem all meltaguns. if you dont have that 'hammer' unit then give them all power weapons and storm shields. also remember that you get the sang priest and his 6 inch bubble. basically, it depends on the rest of your list and what it is lacking, they really are a multipurpose unit. Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702331 Share on other sites More sharing options...
Eorek Posted March 26, 2011 Share Posted March 26, 2011 Melta guns, melta guns, melta guns If you want a melée unit you're better off using vanguards... Honour guard are too few in numbers / lack heroic intervention to be effective They are good as shooty due to the mobility with jump packs + alot of weapons + a "free" sanguinary priest I run mine: with 3 meltas, 1 melta bomb, a blood champion(some CC power atleast... Getting locked in combat with a tac marine squad without a power weapon sucks)...I use them to teminate those mean veichles like anything with a AP2-3 large blast... and they work great vs hordes with their feel no pain + furious charge bubble Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702347 Share on other sites More sharing options...
Gv0zD Posted March 26, 2011 Share Posted March 26, 2011 I prefer Plasma-death Honor Guard - 4 Plasma guns with Jump packs. They support my Vanguard Vets, who act as melee hammer. I think that 4 meltas is overkill, as two would be enough to crack a pred or even an LR, and I have two RAS with 2 meltas each. 4 Plasmas grant you up to 8 AP2 shots, so Termies, Tau Battlesuits and other MEQs with good armor die pretty soon. And the Priest helps with overheating. Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702395 Share on other sites More sharing options...
JamesI Posted March 26, 2011 Share Posted March 26, 2011 I prefer Plasma-death Honor Guard - 4 Plasma guns with Jump packs. They support my Vanguard Vets, who act as melee hammer. I think that 4 meltas is overkill, as two would be enough to crack a pred or even an LR, and I have two RAS with 2 meltas each. 4 Plasmas grant you up to 8 AP2 shots, so Termies, Tau Battlesuits and other MEQs with good armor die pretty soon. And the Priest helps with overheating. I want to build a plasma HG. Think it would be fun, perhaps with 1 powerfist added for defense. Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702430 Share on other sites More sharing options...
Volcatus Posted March 26, 2011 Share Posted March 26, 2011 I love the idea of the plasma guard, but I have to wonder if they need a Storm Shield or two. They are going to eat a ton of fire after they touch down. Of course, this makes them 265 points (ouch!) with two SS. Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702440 Share on other sites More sharing options...
Redfinger Posted March 26, 2011 Share Posted March 26, 2011 well, it really depends on what you need in your army. if you need a surefre way of killing a tank or two then give tem all meltaguns. if you dont have that 'hammer' unit then give them all power weapons and storm shields. also remember that you get the sang priest and his 6 inch bubble. basically, it depends on the rest of your list and what it is lacking, they really are a multipurpose unit. qft...This is really the approach that you should take, determine what you are lacking in your list, then fill in the gaps, HG are a nice "Jack-o-all trades" unit. Now typically DOA lists are lacking in anti-av so that is why many load them out w/ melta, but if you went with some type of "hybrid" DOA like RAS + Dev's then the all melta load out is less of an option. Try to understand WHY you need to unit instead of simply labeling a unit as having a "best of..." type armament..... And lastly, just because you can....doesn't mean you should.... Ashton Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702442 Share on other sites More sharing options...
Mykra Posted March 27, 2011 Share Posted March 27, 2011 Hi guys!I am going to add a honour guard squad to my blood angels force. What wargear should I give them? Some people give them meltaguns, while others make them melee It may seem like a 'Duh, no s-' answer, but it comes down to how you want to use them. If you have a Librarian with Blood Lance, then having a firing squad HG makes the most sense. If the Librarian has Unleash Rage and Sanguine Sword however, tool them up for CC. So I guess the big question is who do you want running with them, and what's that unit(s) goal? That should tell you what your HG should be packing. Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702519 Share on other sites More sharing options...
BLACK BLŒ FLY Posted March 27, 2011 Share Posted March 27, 2011 I like them tooled out for melee - they can really dish out some pain. Here is how I run mine: Chapter banner Honor Guard No. 1: lightning claw & stormshield Honor Guard No. 2: lightning claw & stormshield Honor Guard No. 3: pair of lightning claws Honor Guard No. 4: thunderhammer & stormshield Novitiate I run them with an Epistolary (Sanguine Sword & Unleash Rage) G :fakenopic: Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702534 Share on other sites More sharing options...
Baba Lem Posted March 27, 2011 Share Posted March 27, 2011 I like them tooled out for melee - they can really dish out some pain. Here is how I run mine: Chapter banner Honor Guard No. 1: lightning claw & stormshield Honor Guard No. 2: lightning claw & stormshield Honor Guard No. 3: pair of lightning claws Honor Guard No. 4: thunderhammer & stormshield Novitiate I run them with an Epistolary (Sanguine Sword & Unleash Rage) G :o In a Storm Raven ? Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702642 Share on other sites More sharing options...
Mykra Posted March 27, 2011 Share Posted March 27, 2011 I like them tooled out for melee - they can really dish out some pain. Here is how I run mine: Chapter banner Honor Guard No. 1: lightning claw & stormshield Honor Guard No. 2: lightning claw & stormshield Honor Guard No. 3: pair of lightning claws Honor Guard No. 4: thunderhammer & stormshield Novitiate I run them with an Epistolary (Sanguine Sword & Unleash Rage) G :o In a Storm Raven ? I would guess Jump Packs with DOA. I'm going to try out this set-up tomorrow vs my friends Space Wolves. The unit's something like 500+ points, so they damn well better eat each and every Thunderwolf on the table for brunch. :o Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702643 Share on other sites More sharing options...
BLACK BLŒ FLY Posted March 27, 2011 Share Posted March 27, 2011 Yes of course they have jump packs and they ride in a Stormraven along with a Furioso. They can carve right through thunder pups no problem. :o That's exactly what they were designed to do! G :o Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702654 Share on other sites More sharing options...
Brother_Mike Posted March 27, 2011 Share Posted March 27, 2011 well, it really depends on what you need in your army. if you need a surefre way of killing a tank or two then give tem all meltaguns. if you dont have that 'hammer' unit then give them all power weapons and storm shields. also remember that you get the sang priest and his 6 inch bubble. basically, it depends on the rest of your list and what it is lacking, they really are a multipurpose unit. ^ This. Couldn't have said it better myself. Link to comment https://bolterandchainsword.com/topic/225756-the-best-way-to-run-blood-angeld-honour-guard-in-doa-force/#findComment-2702683 Share on other sites More sharing options...
