Dark Angels Quick Paint
I use gradual layers of mixed DA Green with either Chaos Black or skull white to gradually build up the color I Like. You dont need to use inks but the end result will be a different finish or tone to the models themselves. Since you've decided that Inks arent your thing, or assuming you have, try a 50/50 mix of DA Green with Chaos Black, leave the recesses and do a straight up coat of DA Green and then highlight with either a DAG/Skull mix or a lgihter green. Just thoughts. Good luck.
Yup, mixing is the way to go to maintain that Dark Green look. I used Bleached bone instead of skull white. I used snot green as a highlight in the past.
If you are worried about a shiny wash then try using watered down paints as your wash. They do really well and there is the shoe shine method as well. Get a bottle of black liquid shoe shine (usually a self contained bottle), dab your mini with shoe shine and then dab off with a towel. Instant shading. I was told this was how they added definition when they photographed the unpainted minis for the back catalog section of the old White Dwarfs.
Crap, dated myself there.
I like the method in the back of how to paint citidel miniatures.
Prime black
drybrush entire model dark angel green
drybrush entire model snot green
pick out details details in bleached bone/blood red/boltgun metal
small detail highlights with skull white if you want.
