FenrisWolf Posted March 30, 2011 Share Posted March 30, 2011 Not seeing much in the search, what is the opinion on bases for Fenrisian wolves bought as wargear? Still cavalry or round? And in general, should packs of them be mounted on cavalry bases? Link to comment https://bolterandchainsword.com/topic/226013-bases-for-fenrisian-wolves/ Share on other sites More sharing options...
Growler67 Posted March 30, 2011 Share Posted March 30, 2011 Too many recurring threads on the same repeating questions. In the Unit Description from the Codex (pg 91) they are now classified as "Beasts" instead of "Cavalry". It really depends on the models you use. The common answer is whatever base comes with the model wil be tournement legal. Generally accepted for the GW plastic wolf models, and other similarly sized models from other lines, a Cavalry base would be just fine. If you are wanting to use something bigger, then a larger base may look more appropriate depending on just how much bigger (by comparison) it is. Link to comment https://bolterandchainsword.com/topic/226013-bases-for-fenrisian-wolves/#findComment-2706078 Share on other sites More sharing options...
Grimtooth Posted March 30, 2011 Share Posted March 30, 2011 Cavalry and Beasts are under the same exact heading in the BRB, so the point that they are classified as beasts has no bearing. Your safest bet is to mount them with what they came with or equivalent. Link to comment https://bolterandchainsword.com/topic/226013-bases-for-fenrisian-wolves/#findComment-2706084 Share on other sites More sharing options...
Wulfebane Posted March 30, 2011 Share Posted March 30, 2011 I agonized over whether to put mine on a round 40mm or a bike base. I'm converting mine from chaos warhounds, so putting them on a 40mm would've made some of them slightly top-heavy due to the pose. That and the added wolf tails made them pretty long, so I went with bike bases because I couldn't tolerate square bases for my army. imo, cavalry base (or equiv.) is the way to go. Link to comment https://bolterandchainsword.com/topic/226013-bases-for-fenrisian-wolves/#findComment-2706111 Share on other sites More sharing options...
Natanael Posted March 30, 2011 Share Posted March 30, 2011 I go with 40mm round bases since I cant stand the look of bike bases ^_^ - Natanael Link to comment https://bolterandchainsword.com/topic/226013-bases-for-fenrisian-wolves/#findComment-2706150 Share on other sites More sharing options...
Forté Posted March 30, 2011 Share Posted March 30, 2011 Use the bases which came with them. Perfectly legal. If it has to be rounded the use the bike ones to keep the bases narrow so you can get more into contact and still keep them on a beast type base. Link to comment https://bolterandchainsword.com/topic/226013-bases-for-fenrisian-wolves/#findComment-2706182 Share on other sites More sharing options...
