Damon sword
henrywalker
From a fluff standpoint, possession of a daemon weapon would be heresy of the highest degree. Just look at how much trouble the Relictors got in. Now I imagine the reason you ask is because a certain Grey Knights character uses one. This is a special circumstance. The daemon sword used by Castellan Crowe is unique in that it is indestructible. That is probably the only reason it wasn't destroyed outright. They probably decided that if they couldn't destroy it they would use it. This is a job that only one who is pure beyond belief could fulfill without being corrupted. Crowe is one of the purest of the pure so if any one could wield it, he would be the best choice. No lowly inquisitor could just pick up a daemon sword and just go to town with it. They'd undoubtedly fall to chaos. Even if your inquisitor was as pure as Crowe, and I guarantee he's not, it would still be heresy and he would be executed.
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707335
Sorry mate the Daemonblade is actually a piece of Wargear in the Grey Knights codex that can be taken by Inquisitors (obviously the radical side!). In the codex those in Terminator Armour cant take it.
The answer to the question, however bland it may seem is they just cant. Thems the rules. Dont understand it personally as a sword is a sword but hey ho
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707343
I'm pretty sure he's asking because an inquisitor who has not upgraded to termy armour can take one. :D
The answer is that it's a two-handed weapon. I think. That would make sense. I'm sure someone will immediately come back with a counterexample, but off the top of my head, I can't think of any other time a model in termy armour can wield a two-handed CC weapon.
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707347
Yeh Malleus Inq with TDA can only have a Nemesis Daemon Hammer as his CC weapon. That is all. TDA Inquisitors must not be able to hold any other weapon!! Maybe its the dramatic pose of smiting daemons. "Smite me almighty smiter" Had to :D
Just take a PA armoured guy with the Daemonblade if possible. Its only 48 points!
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707361
I'm pretty sure he's asking because an inquisitor who has not upgraded to termy armour can take one. ;)
Probably an oversight, but we'll see. In Space Wolves codex the Wolf Lord and Wolf Guard Battle Leader couldn't take a Frost Blade when they upgraded to TDA, but this quickly got fixed with the publication of the Errata. I have a feeling that there will be quite a lot to Errata and to answer in the FAQ section for our new codex.
V
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707363
It is a touch odd to have Terminator Inquisitors limited to only a hammer; it makes sense to have a hammer as the default weapon for the Ordo Malleus, but I don't see any reason an Inquisitor couldn't use another weapon, regardless of his armor. Also, for what fluff from the RPGs is worth, the Radical's Handbook does have an Inquisitor who wears Terminator Armor and uses a Daemon Weapon.
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707483
It wouldnt be a Stretch for an Inquisitor to have a Black Carapace, but that Hardly makes them a Marine. Its the combination of all of the organs plus the training plus the mentality that makes a Marine what he is. Above Humans? Yes. Above the Exceptional? Yes. But a Marine? No.
As for a logical reason for no Daemon Weapon for TDA (rules aside) perhaps its that the Inquisitor is in constant mental battle with the weapons and using it with so much armor in between mutes his mind in said fight. AKA the Layers of armor, while providing physical protection, dull his mental battle leaving him open to possession. It may be a stretch but its all I got at the moment.
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707507
Just a quick thought but when an Inquisitor has the ability to take TDA or PA does that mean theyve been fitted with the Black Carapace and any other appropriate organs etc in order to pilot one? Essentially they are a marine then?
Sisters of Battle and Adeptus Mechanicus Enginseers are not implanted with Black Carapace, yet they wear Power Armour. There are many diferent kinds of PA - only the Marine one needs the Carapace.
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707528
I'd sooner believe that a few inquisitors have the resources to have Black Carapaces implanted under the right circumstances.
Or have artificers capable of counterfeiting Astartes power armour, counterfeits which don't need the Black Carapace.
Marines joining the Inquisition sounds like bad fan fiction.
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707559
No, they don't need the Black Carapace to use Power Armour. But it just means that they do not have access to the full spectrum of systems within Astartes armour.
And a human can not get a Black Carapace. But anything can apparently happen in Black Library books... *sighs*
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707603
The Black Carapace is really what makes a marine a marine and turns his armour into a second skin... now it might be possible for a normal human to control astartes power armour (although how would they fit?) but they wouldn't be able to control it in the same way as one of the astartes. You however can get power armour for normal humans but it is normally not as good as astartes power armour (although if you have the dosh and the connections... you can get artificer armour :)) and it still acts like armour rather than a second skin...
Another example of what I'm talking about is that power armour can apparently interface with the controls of a rhino and gives more controls and it is mentioned in one of the enforcer books that the Sisters of Battle can drive rhinos in a way the Adeptus Arbites can't because the Sisters wear power armour which gives them more control... it isn't the same thing but it gives you an idea.
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707621
Think of it this way, would the Grey Knights hand over relics such as Terminator armour (well, they aren't really relics to them, due to how numerous the GK suits are) to Radical scum?
Anyone pure enough of purpose to be allowed TDA, would be above using Daemonic weaponry against their own kind.
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707633
We already know Marines join the Deathwatch- and some do so on a permanent basis.
So what's wrong with the idea of the Inquisition enrolling a marine from, say, a dying chapter- if they think he has the right skillset?
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707667
The problem being that this "marine" is referred to as Inquisitor Gideon- so if the Inquisition had called upon him for aid, they must have later conferred on him Inquisitorial rank.
Or, he's just in disguise- but that still raises the question of how Black Templars are fooled into believing he's a real marine and one of them?
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2707717
Because of the rules?
Also, you're misspelling in the title made my think of Damon Wayans, which then reminded me of the movie Blankman.
sorry typo
It's okay, when Fred was busting you for misspelling "Daemon", he misspelled "your".
V
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2708592
In the Space Marine story Ian Watson mentions that recruits over 18 can be implanted with the Marine organs and will become puissant men, but won't gain the full size and strength of a Marine recruited at 14. The original Dark Angels did that with the members of the Order who wanted to fight alongside Lion El Johnson.
The Inquisition may indeed have members who possess Marine implants but don't have the size of Marines. That would make them more useful in an infiltration role, while still having sufficient strength and durability to have a surprising advantage in a fight along with the ability to interface with suits of power and terminator armour.
https://bolterandchainsword.com/topic/226096-damon-sword/#findComment-2708604
