Nanodave Posted April 1, 2011 Share Posted April 1, 2011 Hi, I've been thinking through this, and I figure at this point, it'd just be best to ask. How do people paint the arrow on the top of Space Marine Vehicles. Normally, I would think that you'd just block it in with masking tape. Or use a template. Figured I'd ask. Link to comment https://bolterandchainsword.com/topic/226273-that-arrow-on-vehicles/ Share on other sites More sharing options...
Montuhotep Posted April 1, 2011 Share Posted April 1, 2011 There used to be a template floating around somewhere - came in an old WD if I remember aright - not sure what happened to it. Masking tape might be your best bit for certain, although asking around in the Tutorials section (or even a search) may yield results. Link to comment https://bolterandchainsword.com/topic/226273-that-arrow-on-vehicles/#findComment-2709526 Share on other sites More sharing options...
averykess Posted April 2, 2011 Share Posted April 2, 2011 Cut one out of plasticard and glue it on. 3D embellishments look better than paint :) Link to comment https://bolterandchainsword.com/topic/226273-that-arrow-on-vehicles/#findComment-2709718 Share on other sites More sharing options...
ShinyRhino Posted April 2, 2011 Share Posted April 2, 2011 I mask mine off using frisket film. It's a sheet of lightly adhesive plastic that is used for airbrushing. Then, I spary the arrows on. 3d versions work, too, you just have to make sure you cut it so it matches the top hatches where the door would open, otherwise you've just welded a solid plate over the top hatch! Link to comment https://bolterandchainsword.com/topic/226273-that-arrow-on-vehicles/#findComment-2709725 Share on other sites More sharing options...
Hyaenidae Posted April 2, 2011 Share Posted April 2, 2011 Freehand. Every time. And my eyes bleed trying to keep it even. Every time. ^_^ ^_^ Link to comment https://bolterandchainsword.com/topic/226273-that-arrow-on-vehicles/#findComment-2709784 Share on other sites More sharing options...
Chapter Master Ignis Domus Posted April 2, 2011 Share Posted April 2, 2011 Freehand it. I do it for all my pack/squad vehicle markings. The large size makes it much easier than on the puny little shoulder pads. Link to comment https://bolterandchainsword.com/topic/226273-that-arrow-on-vehicles/#findComment-2709785 Share on other sites More sharing options...
Gurth Posted April 2, 2011 Share Posted April 2, 2011 Mask it off, you can spray or hand-brush the marking on quite easily then. The arrow on the hatches of a Rhino is simple if you leave the hatches loose, because you can mask and paint it without the rest of the vehicle getting in the way. Link to comment https://bolterandchainsword.com/topic/226273-that-arrow-on-vehicles/#findComment-2709906 Share on other sites More sharing options...
winterdyne Posted April 2, 2011 Share Posted April 2, 2011 Pencil, home made flexible ruler, then paint it on by hand. Link to comment https://bolterandchainsword.com/topic/226273-that-arrow-on-vehicles/#findComment-2710023 Share on other sites More sharing options...
Wicksy Posted April 4, 2011 Share Posted April 4, 2011 I drew one on squared paper, cut it out and then marked the area in pencil on the tank and free handed it. Link to comment https://bolterandchainsword.com/topic/226273-that-arrow-on-vehicles/#findComment-2712077 Share on other sites More sharing options...
NemFX Posted April 5, 2011 Share Posted April 5, 2011 Draw a big arrow on a piece of paper, cut it out, put it on top of your tank, paint around it as carefully as you can. Link to comment https://bolterandchainsword.com/topic/226273-that-arrow-on-vehicles/#findComment-2712784 Share on other sites More sharing options...
Red Fury Posted April 6, 2011 Share Posted April 6, 2011 ooh, check these out: http://chapterhousestudios.com/webshop/com...p;category_id=4 Link to comment https://bolterandchainsword.com/topic/226273-that-arrow-on-vehicles/#findComment-2714982 Share on other sites More sharing options...
