maxbott Posted April 2, 2011 Share Posted April 2, 2011 Simple question, what size resin bases do you use for Dreadnaught basing? Stormraven? Thanks for your time Link to comment https://bolterandchainsword.com/topic/226341-resin-bases-question/ Share on other sites More sharing options...
sniperhavens Posted April 3, 2011 Share Posted April 3, 2011 I believe its 60mm for the dread and 40mm for Termies Link to comment https://bolterandchainsword.com/topic/226341-resin-bases-question/#findComment-2711161 Share on other sites More sharing options...
Brother Valerius Posted April 3, 2011 Share Posted April 3, 2011 It is. The Stormraven is a weird base, something like 120mmx90mm? It's oval shaped, and GW doesn't list the dimensions on the site, unlike for most models. :( Link to comment https://bolterandchainsword.com/topic/226341-resin-bases-question/#findComment-2711493 Share on other sites More sharing options...
chromedog Posted April 3, 2011 Share Posted April 3, 2011 Stormraven/Valkyrie base is 120x94 and is a large oval. It's also the same base used on the big lotr elephant thingy (hence its copyright year of 2006). 60mm for dreads. 40mm for terminators. Link to comment https://bolterandchainsword.com/topic/226341-resin-bases-question/#findComment-2711526 Share on other sites More sharing options...
