Psychic Hoods and Aegis
MontyBob
Yes I dont belive it is suggested anywhere that a psychic hood is a phychic power for any game purposes.
Unless they changed the wording significantly in the new GK book not a single psychic defense in the game is itself a psychic power.
I always thought that was odd though.
You guys seem to be interpreting the question as if the Aegis affects the psychic hood directly (asking if it makes your opponent's use of a hood more difficult), but I think the question is thus. If a psychic power is cast at a unit with the Aegis, and you attempt to nullify it with a psychic hood, does your opponent roll with his natural leadership in the opposed roll, or does he roll with the leadership score he used to make the original psychic test?
It isn't necessarily a use of wargear. When a psyker without a psychic hood casts a power, and you use the hood on it, they get an opposed roll even though they don't have a hood. I don't know that I'd classify it as a psychic power, per se, but it isn't that big of an inference to say that the same leadership score applies. I'm just wondering if there's a solid rule one way or the other.
I very strongly suspect that there are no grounds anywhere in the rules to count a pshychic hood as anything but wargear with a specificly defined effect. The aegis will only ever effect the enemys attempt to cast the power as I read it, the Hood roll off to try and nulify it appear to be a separate event.
If prescident to the contrary can be found of cource that is a different matter...
