Uprising Posted April 3, 2011 Share Posted April 3, 2011 For my diy chapter, i am using both C:SM and the space wolf codex to represent my idea. The biggest problem i am facing is the different option in the codexes. Since i hate spending money, i have decide to magnetize the arms of all my power armour and terminator marines. I plan on ordering from thewarstore.com but can`t decide of which size. Here the link for the magnets--- http://www.thewarstore.com/magcraft.html So which size is best? As always thank you for your time. Link to comment https://bolterandchainsword.com/topic/226385-which-size-magnets/ Share on other sites More sharing options...
Quixus Posted April 3, 2011 Share Posted April 3, 2011 The link does not work. Anyways to magnetize arms and backpacks I used 3mm x 1mm on both parts. They are just the right size. If you want to magnetize hands or combiweapons you will have to go smaller. The magnets are even strong enough to hold the metal bolt pistol arm on the Librarian. Drilling the holes was a pain though. If you do lots of magnets, get a dremel or an electric drill. Just check the polarity and use the same combination for every model. Link to comment https://bolterandchainsword.com/topic/226385-which-size-magnets/#findComment-2711051 Share on other sites More sharing options...
Tabgoi Posted April 4, 2011 Share Posted April 4, 2011 Here is a list of the numbers and sizes of magnets I use and what I use them for. Mind you they are in inches because that's what K&J magnets uses and they have been great for me. Also, when you see a N52, that indicates a stronger magnet for that size, I tend to use the weaker ones because they are cheaper and you can still lift a mini with them no problem, even metal minis. D101-N52 1/16" X 1/32" For use when magnetizing hands, these go into the hands D201 1/8" X 1/32" For use when magnetizing arms and back packs. For metal back packs (heavy weapons and Techmarines) use the D201-N52. D12-N52 1/16" X 1/8" For use when magnetizing hands, these go into the arms. They are cylinders. D601 11/16" X 1/32" For Dreadnaught Arms. Hope this helps. Link to comment https://bolterandchainsword.com/topic/226385-which-size-magnets/#findComment-2711614 Share on other sites More sharing options...
averykess Posted April 4, 2011 Share Posted April 4, 2011 You may find my magnet tutorial helpful. Link in my sig... Link to comment https://bolterandchainsword.com/topic/226385-which-size-magnets/#findComment-2711639 Share on other sites More sharing options...
Uprising Posted April 5, 2011 Author Share Posted April 5, 2011 You may find my magnet tutorial helpful. Link in my sig... Your tutorial gave me the idea in the first place. It was one of the best tutorial i have ever seen. Thank you for putting it up. Tabgoi--- thanks that what i am looking for. now i just have to place an order. Quixus--- The link was me bad but atleast it was fix. metal would be difficult but good thing i am not using any metal models. Link to comment https://bolterandchainsword.com/topic/226385-which-size-magnets/#findComment-2713194 Share on other sites More sharing options...
