fire!
Well, one good way would be to sculpt some flames on him first, this isn't hard, just stick a few blobs of GS on here and there and attack the blobs with your clippers (gently) and modelling tool of choice.
Then do a bit of layering, start with a dark red, then, leaving some dark red at the base and in the recesses, highlight with successive layers of lighter red, orange, yellow, and eventually white, with the lighter colours towards the tips of the flames
https://bolterandchainsword.com/topic/226457-fire/#findComment-2712052
I much prefer it if you highlight fire "inside out", i e white in the middle and darker tips, since that is how a lot of flames actually look.
https://bolterandchainsword.com/topic/226457-fire/#findComment-2712374
AGreed - fire tends to be brighter towards the middle of the flame although not in the dead centre. If you can get some clear resin, then you could even model some flames in this (use plaster or GS to make a mould, dip in the resin a few times to produce a cone of flame.
https://bolterandchainsword.com/topic/226457-fire/#findComment-2713570
