Forté Posted April 9, 2011 Share Posted April 9, 2011 Finally got a Space Wolf marines and what a shock when I find that 3 of the heads have no necks!!! Does this mean hacking the neck of a random helmet to make it sit right on the body? Glad this isn't my first kit. Link to comment https://bolterandchainsword.com/topic/226952-heads-with-flat-necks/ Share on other sites More sharing options...
Growler67 Posted April 9, 2011 Share Posted April 9, 2011 A small ball of GS will work. Or you can trim down a section of sprue instead of hacking an helmeted or other head. Just trim down the spur section carefully with your knife and glue it on. After it dries yo can then use a small file to get the shape you want. Link to comment https://bolterandchainsword.com/topic/226952-heads-with-flat-necks/#findComment-2718424 Share on other sites More sharing options...
Forté Posted April 9, 2011 Author Share Posted April 9, 2011 Many thanks Link to comment https://bolterandchainsword.com/topic/226952-heads-with-flat-necks/#findComment-2718427 Share on other sites More sharing options...
Arez Posted April 9, 2011 Share Posted April 9, 2011 theres also a couple torsos that have no neck hole.they are just flat where the head sits.jsut FYI if you didn't see them Link to comment https://bolterandchainsword.com/topic/226952-heads-with-flat-necks/#findComment-2718428 Share on other sites More sharing options...
muadib02 Posted April 9, 2011 Share Posted April 9, 2011 the heads with flat necks are to throw on SM Scouts...it works pretty well Link to comment https://bolterandchainsword.com/topic/226952-heads-with-flat-necks/#findComment-2718429 Share on other sites More sharing options...
Max_Dammit Posted April 9, 2011 Share Posted April 9, 2011 No, there are 3 marine helmets that have no ball and there for the torso with no hole in the top, but removing it from one of the 1000 helmets i have works. Link to comment https://bolterandchainsword.com/topic/226952-heads-with-flat-necks/#findComment-2718431 Share on other sites More sharing options...
Forté Posted April 9, 2011 Author Share Posted April 9, 2011 But the heads in question look more like two are for WG or LF and the other is more of a BC Link to comment https://bolterandchainsword.com/topic/226952-heads-with-flat-necks/#findComment-2718433 Share on other sites More sharing options...
Chapter Master Ignis Domus Posted April 9, 2011 Share Posted April 9, 2011 The heads with no neck are intentional. They are meant for the hole-less torsos. Link to comment https://bolterandchainsword.com/topic/226952-heads-with-flat-necks/#findComment-2718443 Share on other sites More sharing options...
Forté Posted April 9, 2011 Author Share Posted April 9, 2011 Not enough ale me thinks. Only just spotted that one after your post. Now I shall go and hide in the corner. Link to comment https://bolterandchainsword.com/topic/226952-heads-with-flat-necks/#findComment-2718446 Share on other sites More sharing options...
Beef Posted April 9, 2011 Share Posted April 9, 2011 Not enough ale me thinks. Only just spotted that one after your post. Now I shall go and hide in the corner. That would be best Link to comment https://bolterandchainsword.com/topic/226952-heads-with-flat-necks/#findComment-2718515 Share on other sites More sharing options...
Forté Posted April 9, 2011 Author Share Posted April 9, 2011 *from the corner* Ales on the bar for you Link to comment https://bolterandchainsword.com/topic/226952-heads-with-flat-necks/#findComment-2718529 Share on other sites More sharing options...
