Honour Guard Novitiate
1Drop
He cannot be upgraded in any way so it is just bolt pistol/CCW or Bolter for this buddy, only a JP can be added. Also, he is an integral part of the squad so he cannot be targeted by enemy specifically like your other SP's but he also cannot leave the squad. He must be present in the squad as well. Simply, he is just a common member of the HG who's upgrade option was spent on the blood chalice he has. The lack of PW is crappy but otherwise, he is a VERY cool thing to have around as he is not a IC.
You don't necesarily have to have his Narthecarium arm represented, it can be hard (and pricey) to find that bit sometimes. I'd say a bolt pistol and chainsword arm combo would be fine, just toss a few flashy bits with grails on him to denote his position and that should get the point across. It's really up to you how you want to represent his station, a white helmet or shoulder pad trim could do the trick too.
Yeah, I'm using the DA veteran kit to make my HG, there was supposed to be bits to create
An apothecary in there but there wasn't (instead there is a crozius arcanum which I'm not comPlaining about)
So yeah I think I'll use some of the DC bits with chalices on, other than that I'll paint them gold with crimson robes
(scab red probably) and then use the DC jetpacks and I'm working on making a flamer/melta as you can replace
both bolt pistol and chainsword (on regular HG) with one of each so a combination. Of both weapons will be the best
Way to represent this I feel!
So I should just model him with a chainsword and a bolt pistol, no need for that apothecary arm thingy or anything?
Drop,
I kit bashed my Narth on my Sang Initiate. You can check him out in my WIP thread HERE
Maybe you can use it for inspiration. Cheers,
-CC
