Byrne Posted April 11, 2011 Share Posted April 11, 2011 Hi, I was reading the GK codex, and I looked at the S-B rule. it say "items of wargear" so stormshield is an equipment, does that mean S-B don´t work on an armou or storm shield? Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/ Share on other sites More sharing options...
Iron Father Rik Posted April 11, 2011 Share Posted April 11, 2011 Storm Shield is a piece of wargear. You could also use the word "equipment" to describe it. It is the same thing. "Wargear" is merely a term to describe a piece of "equipment" that is specificaly for use in a war situation. Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2720503 Share on other sites More sharing options...
lordsloth Posted April 11, 2011 Share Posted April 11, 2011 Im fairly certain armour shields equipment and weapons are all wargear. i think the only thing it doesnt work against is innate invulnerable saves that come from dodging, being a daemon or other things like that. Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2720506 Share on other sites More sharing options...
Byrne Posted April 11, 2011 Author Share Posted April 11, 2011 what trow me of is the different labels, equipment, wargear armour and such... not crystal clear,,, Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2720511 Share on other sites More sharing options...
Byrne Posted April 11, 2011 Author Share Posted April 11, 2011 Was told wargear is equipment and such.. :) Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2720518 Share on other sites More sharing options...
Seahawk Posted April 11, 2011 Share Posted April 11, 2011 Wargear = equipment = items = all smashed by Shield-breaker. Terminology is loose in Warhammer, and if one is coming from a game like MTG or other such things, it's hard to adjust! Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2720529 Share on other sites More sharing options...
501st Posted April 13, 2011 Share Posted April 13, 2011 To Clarifiy. Shield Breakers Effect all forms of invunerable save that are given by a peice of war gear or equipment. they had to specify cos in the draft codex (i have a copy and trust me the finished is alot better) it was simply destroys your invulnerable but they found that if you shot a daemon with it the daemon no longer had any save. Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2722514 Share on other sites More sharing options...
BrotherWasted Posted April 13, 2011 Share Posted April 13, 2011 The term "wargear" is not loose at all. Everything that is standard issue for a specific unit comes under the heading of "Wargear" in their unit entry. The term "Equipment" is a sub-heading under the Wargear section of your Codex. Therefore, as written: The Vindicare takes away any invulnerable saves that come from something that is listed in the Wargear chapter of your Codex. I would also argue that Shield Breaker DOES break through Demonic Gifts. Demonic Gifts are by their definition described as "equivalent to the weapons and other wargear used by mere mortals". Therefore; Demonic gifts are wargear, and as such any invulnerable save granted by them is ignored by Shield Breaker. Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2722522 Share on other sites More sharing options...
Reclusiarch Darius Posted April 13, 2011 Share Posted April 13, 2011 90% of invul saves are from wargear anyway, so it's hardly a massive problem. Anyway, Shield Breaker is hardly going to be the most used ammo. Turbo-Penetrator is just hilarious, it's pretty much a guranteed penetrating hit every turn on virtually any piece of armour. Sure there is cover (and you can roll badly for damage, as I always seem to do), but it's still pretty good. Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2722536 Share on other sites More sharing options...
Cpt. Blood Donator Posted April 13, 2011 Share Posted April 13, 2011 90% of invul saves are from wargear anyway, so it's hardly a massive problem. Anyway, Shield Breaker is hardly going to be the most used ammo. Turbo-Penetrator is just hilarious, it's pretty much a guranteed penetrating hit every turn on virtually any piece of armour. Sure there is cover (and you can roll badly for damage, as I always seem to do), but it's still pretty good. I can think of... Assasin agility and Sanguniors inv. save as not being wargear. Surely there are a few more, but as you say; most goes away =) Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2722670 Share on other sites More sharing options...
JamesI Posted April 13, 2011 Share Posted April 13, 2011 90% of invul saves are from wargear anyway, so it's hardly a massive problem. Anyway, Shield Breaker is hardly going to be the most used ammo. Turbo-Penetrator is just hilarious, it's pretty much a guranteed penetrating hit every turn on virtually any piece of armour. Sure there is cover (and you can roll badly for damage, as I always seem to do), but it's still pretty good. I can think of... Assasin agility and Sanguniors inv. save as not being wargear. Surely there are a few more, but as you say; most goes away =) Demons, Chaos Lords, Sorcerors, Possessed all have invuls independent of wargear. Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2722699 Share on other sites More sharing options...
Brother Valerius Posted April 13, 2011 Share Posted April 13, 2011 Turbo-Penetrator is just hilarious, it's pretty much a guranteed penetrating hit every turn on virtually any piece of armour. Sure there is cover (and you can roll badly for damage, as I always seem to do), but it's still pretty good. True. Still, thanks to AP1 you have a 50% chance to kill it on the damage roll, which isn't too shabby. Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2722757 Share on other sites More sharing options...
The Rose Princes Posted April 13, 2011 Share Posted April 13, 2011 on top of that tyranids do not have any wargear. Link to comment https://bolterandchainsword.com/topic/227127-vindi-assassin-shield-breaker/#findComment-2722830 Share on other sites More sharing options...
