Melta, Plasma, Flamer etc.
..or you could see if there is a difference in detailing (if any), or maybe one of the wrists is positioned in a way you like better? Or maybe the model is a bit unbalanced and using plastic would improve weight issues?
There is no 'right' answer other than using the method you prefer. As others pointed out, plastic is easier to cut (cleanly) then metal, so you could say that is a 'better' method. Still doesnt matter though.
