Twipp Posted April 14, 2011 Share Posted April 14, 2011 Hi one short question about the Runic staff rule. We know that it gives you a change to nullify the enemy psycic powers with a roll +4 and if the Priest is standing not futher than "24 from the target. But if you have 3 Rune Priest does it then stack? can you roll 3D6 when enemy is using psycic power and all those 3 priests are inside that area. Link to comment https://bolterandchainsword.com/topic/227443-question-about-multiple-rune-priests/ Share on other sites More sharing options...
Sarapham Posted April 14, 2011 Share Posted April 14, 2011 Hi one short question about the Runic staff rule. We know that it gives you a change to nullify the enemy psycic powers with a roll +4 and if the Priest is standing not futher than "24 from the target. But if you have 3 Rune Priest does it then stack? can you roll 3D6 when enemy is using psycic power and all those 3 priests are inside that area. Nope just one time. Its in the Space Wolves FAQ. Link to comment https://bolterandchainsword.com/topic/227443-question-about-multiple-rune-priests/#findComment-2724659 Share on other sites More sharing options...
Twipp Posted April 14, 2011 Author Share Posted April 14, 2011 Thanks. Link to comment https://bolterandchainsword.com/topic/227443-question-about-multiple-rune-priests/#findComment-2724665 Share on other sites More sharing options...
MaveriK Posted April 15, 2011 Share Posted April 15, 2011 Hi one short question about the Runic staff rule. We know that it gives you a change to nullify the enemy psycic powers with a roll +4 and if the Priest is standing not futher than "24 from the target. But if you have 3 Rune Priest does it then stack? can you roll 3D6 when enemy is using psycic power and all those 3 priests are inside that area. silly pup, the only thing that will ever stack onto one another is during the spring! and I dare you to go out alone in the fields of Asaheim during that time, just for you to learn a lesson. It's just like trying to stack two frost blades together, cause they wont stack your strength.. even if you add duct tape, you'll just look like your playing cricket with the enemy. Link to comment https://bolterandchainsword.com/topic/227443-question-about-multiple-rune-priests/#findComment-2724836 Share on other sites More sharing options...
Twipp Posted April 15, 2011 Author Share Posted April 15, 2011 Thanks Mav. This puppy has truly learned his lesson about this subject :D Link to comment https://bolterandchainsword.com/topic/227443-question-about-multiple-rune-priests/#findComment-2724869 Share on other sites More sharing options...
