Grand Master Inpensus
henrywalker
What are you looking for from us?
Feedback?
Critique?
Suggestions?
IMO it is a good conversion, but you painting skills need some work. I think your base coats are too bright. For example, I choose to prime black, then base coat tin bits, then drybrush boltgun, then selectively drybrush chainmail, then highlight mithril. Using a dark brown before adding dwarf bronze, then shining gold highlight really makes the gold pop.
The silver looks alright, a bit thick in some places, but not too bad.
Have you tried a layered approach to the gold? I use a Tin Bitz base, followed by a somewhat generous Shining Gold drybrush (halfway between drybrush and overbrush), a Badab wash, and a final drybrush of Burnished Gold.
all three would be great. he isn't painted though, literally the first layers of paint on the various areas have just been put on. i think its the camera/lighting as it seems quite dark in real life
Thanks for the feedback
I assumed it wasn't done being painted. I was just commenting on your base coats, they looked light in the picture.
Looks decent. Kind of static though. Might want to run some tubes to the Incinerator so it doesn't look like you just tacked it on. :D
yeah i thought the same thing, but that is how t is meant to be, i may GS some stuff on. i tried using a promethium tank from the dreadknight but it looked like too much on one arm
camera, thanks though
