Assembling Psycannons
Tribal-Bob
Get some good, thick plastic cement. Those that are so thick, it starts melting the second you apply it. Rapidly apply them to all the joints and hold them together. I did that for my GKSS psycannons, and they went on fine without much hassle :tu:
(I used the thick Tamiya cement, white cap, not the yellow or green capped ones).
What I do is take a very, very tiny ball of green stuff and attach all the points that need attaching. Once I get it aligned in position, its just a matter of going to all the points with green stuff and applying a dab of glue. This is about the best way I have found to get it right.
Um? Or bluetac? Its cheaper. I bluetacked the right arm to the torso, then glued the gun to the right arm and checked the fit of the right arm. If that was all good, glue the right arm to the torso (by removing the bluetac first), if not, by using plastic glue you have a bit of time to reposition things before it sets. Then glue the left arm to both the gun and the torso.
Definitely a pain.
Definitely a pain.
I might try the bluetac - I'm actually running into the same problem with the force swords now, too. I swear, why can't GW just use a triangular tab and hole like they do on the new devastator marines.
This is made worse by the fact that I don't want to glue the weapon in yet (I like to paint it separately so I can get in around the chest with my brush easier.) The blue tac might work best, though.
Might need to go buy some, I think mine's so old it no longer holds... anything.
