scouts?
amrogers3
theyd need some fairly major work, new guns, changing heads, removing chaos symbols, and swapping out that banner for something. that said at the end of the day the mdoels are beautiful but it think after making those changes they will look quite similar to regular "normal" scouts only more expensive and more conversion. that said i think you could do a fairly good job if instead you used the chaos marauders box and box of scouts compared to this. then again that is more expensive but in the end its all about how much work you put in to pull it off. i think you could do a very beautiful conversion with those guys just not sure its worth the time.
https://bolterandchainsword.com/topic/227996-scouts/#findComment-2731636
