orbion Posted April 23, 2011 Share Posted April 23, 2011 So my question Is are there only the metal vanguard vets? becuase buying them static is going to be expensive as opposed to buying the box of 5. And when you get the box of 5 they all have things on them i don't want. Any advice on either how to convert another model for it or something i can kitbash onto then to make then not so bad? Thanks in advance. Link to comment https://bolterandchainsword.com/topic/228215-vanguard-veterans/ Share on other sites More sharing options...
RebG Posted April 23, 2011 Share Posted April 23, 2011 As far as official models go the boxed set (or individual versions of those from the boxed set) are pretty much it. There's a mail order only Blood Angel one but that's about it. The good news is they're easy conversions/kit-bashes. Remember they're basically assault marines with a few extra spangly bits to show they've been arond for a while. It's up to you what you use. My Angel Sanguine VV use Sanguinary Guard bodies with regular heads, arms and weapons, painted normally but with extra gold and/or white trim. You can apply a lot of that to most chapters, just go through all those spare little bits, purity seals, grenades etc that you might have lying about and make them look a bit more kitted out than a regular marine. Link to comment https://bolterandchainsword.com/topic/228215-vanguard-veterans/#findComment-2734644 Share on other sites More sharing options...
Arikel Posted April 23, 2011 Share Posted April 23, 2011 My vets have a reversed color scheme to my ordinary marines, a few extra flashy bits, and silver trim(metallic version of white) to denote membership in the first company, I have a mix of plastic vets and some metal figures. Link to comment https://bolterandchainsword.com/topic/228215-vanguard-veterans/#findComment-2734698 Share on other sites More sharing options...
Larkyn Posted April 23, 2011 Share Posted April 23, 2011 Forge World has a Red Scorpions vanguard veteran conversion kit if you want to be cool. Link to comment https://bolterandchainsword.com/topic/228215-vanguard-veterans/#findComment-2734701 Share on other sites More sharing options...
orbion Posted April 24, 2011 Author Share Posted April 24, 2011 Im not really talking about what they LOOK like so much as their layout of items ( power fist, Lightning claw etc... ) so i guess what im asking is are the arms already connected to the metal model or do i have to chop them off and replace it? Link to comment https://bolterandchainsword.com/topic/228215-vanguard-veterans/#findComment-2734950 Share on other sites More sharing options...
AngryJohnny Posted April 24, 2011 Share Posted April 24, 2011 Take a look here, it may be helpful: Â Vanguard Veterans (Scroll to about the middle of the post) Metal Veterans Mk2 Metal Veterans Mk1 (Scroll to the end of the post) Link to comment https://bolterandchainsword.com/topic/228215-vanguard-veterans/#findComment-2735252 Share on other sites More sharing options...
Arikel Posted April 24, 2011 Share Posted April 24, 2011 http://www.games-workshop.com/MEDIA_Custom...ain_873x627.jpg  These are the templar swordbrethren, some templar iconography but also excellent for vanguard marines.  If you want your own loadouts you are better off pimping up plastics.  All the metal models are one solid piece for the most part, the sword brethren above, are 1 chainsword marine with bolt pistol glued on, one power sword marine with bolt pistol glued on, 2 boltpistol marines with chainswords glued on, lc marine is one solid piece. The spearate weapons are separated at the wrist(so hand and weapon is glued to the wrist). Not sure how many pieces the other models listed above are, answer might be in the sprue collection picture thread. Link to comment https://bolterandchainsword.com/topic/228215-vanguard-veterans/#findComment-2735495 Share on other sites More sharing options...
crandall87 Posted April 24, 2011 Share Posted April 24, 2011 I really like the FW Red Scorpion Vanguard vets. You could also consider using the Sanguinary Guard, they would make awesome Vanguard Link to comment https://bolterandchainsword.com/topic/228215-vanguard-veterans/#findComment-2735513 Share on other sites More sharing options...
elohimalpha Posted April 24, 2011 Share Posted April 24, 2011 Like RebG said, the only official VV models are all metal, but the weapons options for each can all be found in plastic, and you'll be able to create a much more customizable force if you use the plastics. I recently made my own VV out of assault marines, and used weapons from various kits - mostly bits from the Death Company box that didn't have too much Blood Angels iconography, but there's some Sanguinary Guard shoulders, Black Templar helmets, and some other pieces. The only metal part I used was the right lightning claw, which is from a metal veteran model. It was a separate piece too, so no cutting was required. Check 'em out here if you're interested. The poses aren't as dramatic as the metal VV, which are really nice models, but with a little GS, they can be as ornate, and these will be a lot more flexible tactically. Link to comment https://bolterandchainsword.com/topic/228215-vanguard-veterans/#findComment-2735514 Share on other sites More sharing options...
Dwarfkernow Posted May 2, 2011 Share Posted May 2, 2011 I am using a space wolf box set for my vanguards and sternguard, check my blog for the pics. You should be able to file off the space wolf icons. hope that helps. Link to comment https://bolterandchainsword.com/topic/228215-vanguard-veterans/#findComment-2744701 Share on other sites More sharing options...
red_starrise Posted May 2, 2011 Share Posted May 2, 2011 I'm making a unit of Sternguard for my IF using the DA upgrade frame & my bits box. Also making Vanguard using the command squad champion pieces (I have several). Link to comment https://bolterandchainsword.com/topic/228215-vanguard-veterans/#findComment-2744847 Share on other sites More sharing options...
