HarasinCreed Posted April 24, 2011 Share Posted April 24, 2011 Hi there i was wondering if anyone had a good tutorial on building banners or wants to put on together :tu:. This is for my Golden Deamon miniature so it will need to come out quite high quality'. Thanks Edmund Link to comment https://bolterandchainsword.com/topic/228243-how-to-build-banners/ Share on other sites More sharing options...
crandall87 Posted April 24, 2011 Share Posted April 24, 2011 Are you looking on using printed banners or painting them yourself? Link to comment https://bolterandchainsword.com/topic/228243-how-to-build-banners/#findComment-2735508 Share on other sites More sharing options...
S'jet Posted April 24, 2011 Share Posted April 24, 2011 If you are planning on Greenstuff... i found a tutorial for a tabard which could easily be used for banners or any type of cloth.. Tabard Tutorial Just make the creases shallower if you plan to freehand on it. Link to comment https://bolterandchainsword.com/topic/228243-how-to-build-banners/#findComment-2735617 Share on other sites More sharing options...
Durus Posted April 25, 2011 Share Posted April 25, 2011 Making Plastic Banners on CMON. Would give you a solid base to sculpt further details on, like purity seals or anything else you can think of. Link to comment https://bolterandchainsword.com/topic/228243-how-to-build-banners/#findComment-2735723 Share on other sites More sharing options...
HarasinCreed Posted April 25, 2011 Author Share Posted April 25, 2011 Thank u guys i will use the tutorial Durus Link to comment https://bolterandchainsword.com/topic/228243-how-to-build-banners/#findComment-2735747 Share on other sites More sharing options...
