EPK Posted April 26, 2011 Share Posted April 26, 2011 I just bought some accessories that included this bit and I wanted to use it on my Deathwing Command Squad Sarge. Question is in the title, any of you that have it or have already used it, do you think or know if it will work easily with regular terminator models? The problem I see just form images on the web is that it looks like it may actually be cut out on the sides to conform to the GK terminator leg plates. I don't think regular terminator leg plates come as far towards the center, so I am predicting there will be some gaps that I'm probably going to need to fill with greenstuff to work right, but I wasn't sure. Regardless, it's already ordered, if I have to do some fiddling to get it to work, so be it. Just wanted to get some opinions or see if anyone has tried it. Feel free to link an image if you have. Link to comment https://bolterandchainsword.com/topic/228448-grey-knight-terminator-tabard/ Share on other sites More sharing options...
henrywalker Posted April 26, 2011 Share Posted April 26, 2011 that things annoying, you need to attach it before you attached the body to the legs (or probably at the same time is best) Link to comment https://bolterandchainsword.com/topic/228448-grey-knight-terminator-tabard/#findComment-2737798 Share on other sites More sharing options...
EPK Posted April 26, 2011 Author Share Posted April 26, 2011 Heh, I don't like the sound of that. Can it really be that difficult? It did look odd... the chain seems to fit over the leg plates but the tabard itself under. EDIT: Now that I think of it though, I can probably use some other random sensor bit type thing to cover up any gaps with minimal green stuffing. Link to comment https://bolterandchainsword.com/topic/228448-grey-knight-terminator-tabard/#findComment-2737842 Share on other sites More sharing options...
