WIP DA shots
skink
Well, I've finally scraped together the courage to post some of my painting on the interwebs...
I admit that painting isn't my favorite part of the hobby, but my hope is that by publicising my results, I'll be pushed to do more. As such, comments, reccommendations and (gentle!) criticism is welcomed! My pre-emptive excuse: bear in mind that these represent more or less my entire painting history (in addition to 6 Empire militiamen, and a couple of Lizardmen!).
So, without further ado, let's start with a couple of speeders that I did today while the whole country ground to a halt; I haven't done the crew as I'm a bit scared of them!
A pair of Typhoons, which have multimeltas
The one on the left...
The one on the right...
Urgh, all the mistakes leap out on screen eh?! I know that the highlights are a bit clunky, but I hope these will become more defined as time goes on! They also look ok at arm's length, so should be alright for gaming standard; all I am aiming for. Some Deathwing to come shortly...
https://bolterandchainsword.com/topic/228688-wip-da-shots/
Terrible, throw them into universal solvent and burn the rest of your models.
Now seroiusly, they look fine to me :mellow:
As you say, the highlights are a bit thick, but all you need to do is cover the excess with black paint and you are good to go.
Keep it up!
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2741572
I've found that all the fancy techniques in the world look terrible if you can't paint cleanly. your models especially your metals are very clean and well defined. That alone IMO does more for the overall quality of a model than any of the more "advanced" techniques you hear about.
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2741584
Wow, quick responses guys, and thanks for kind words!
Tanhausen: I had them really thin to start with, especially on the sharper edges (I would lightly coat the brush in paint, then hold it at right angles to the edge I was highlighting and run it along), but as soon as you were more than 30 cm away you couldn't see them. When I tried to make them more obvious, the thick splodging started... But practice (hopefully) makes perfect...
VAGABOND: Codex Grey my friend, simply straight over the Black Spray undercoat. As I said, painting isn't really my thing, so I tried to keep it quick and simple! A wash is a good idea; I might experiement with some Badab...
puck: Thanks for that, a real confidence boost!
Okay, DW time... Again, not finished (haven't highlighted one squad, I pretty sure that none of the arms are done, and I'm wary about doing bare heads) but they are well on their way. All arms are magnetised; I really enjoyed modelling these guys. Maybe a bit dark for traditional DW, but it's so easy and I've started to like the dirty look...
Command squad...
Standard and Sarg...
Apothecary and Cyclone
Other squad... The random bone/white based claws guy was a colour experiment that I hated, and will ultimately strip.
Some of the chaps...
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2741602
Everything is coming along nicely skink. I especially like your take on the 2 shot CML. Yours makes perfect sense. The doubled headed mace that is now a staff is cool too. Some fun kitbashes you got going on there.
Thought it was worth mentioning that you can mount those old metal terminators, base and all, right onto a second 40 mm base if you care to. It lifts them up in height to match the newer models. With the right basing elements you can't even tell there are two bases - here is one of my models when it was still a WIP for reference.
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2741696
Thanks for your words of encouragement! I really enjoy smashing together kits, I'm all about simple but effective conversions; my favorites are when you look at a model and can't tell if it's been modified or not!
Ask, and ye shall receive!! Belial with claws... I know his blade is on a wonk, but it's snapped off too many times now, and I magneted it a bit skew wiff... If I was doing it again, I'd include some putty to make it less of a step, and may do so for the rest. Nice reference model btw, you've got a nice light colour.
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2741705
The models look great :tu:. The DW are nicely but not overly kitbashed. I love your take on cyclones – very creative. The sgts power maul is an idea well worth nicking :whistling:.
But you don't need our encouragement to keep you going – you're doing fine on your own <_< .
Cheers
I
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2742654
Thanks for the continued encouragement guys!
The cyclone conversion was a matter of finances: I wanted them on every squad, but post-FAQ the Cyclone bit (plastic and metal alike) were as rare as hen's teeth and expensive to boot. These are HK missiles on their side and glued together; cheap and simple! The maul is two DA maces glued to a stormbolter arm; I needed another hammer!
Work means I'll spend the next couple of months abroad, so I won't be updating anytime soon, but I did take all the guys featured so far and a RW meltagang against Slannesh Marines and nearly tabled them (fluffed a 4 in 6 chance of blowing up the final tank, having only lost 7 Terminators, 4 bikes and a speeder); a combination of freshly painted models and him using my dice caused Lady Luck to smile on me! Lash against footslogging Terminators is lethal btw, routinely undoing multiple turns of positioning. Any sneaky ideas to combat this, or do we just kill the Sorcerer ASAP?!
Something that did come was the manager of the store wanting me to base the metal Terminators on 40 mm bases. Part of me would rather they stayed on 25 mm and I figure this is legal as GW still supply them on the smaller bases, but I don't really care and local tournament rules (which I would like to start attending once the painting is done) dictate that all Terminators must be fielded on 40 mm bases. Should I stick to my guns and keep them on the smaller bases (for no real reason in particular!!) or should I just pop them on the bigger ones? Will there be an in game difference?
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2746479
The only advantage IMO for smaller bases is that templates touch let models.
Bigger bases give you the advantage of having a broader front, which means more models in CC and you can reach more when stretching the unit (for example, to capture 2 objectives).
For simplicty's sake, I'd base them in 40mm.
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2746513
EPK, as an aside, your Consecrators are banging. Really impressed with them. Are there going to be more?!
Why thank you! I have four left to paint, 3 marines and a sarge from that tactical squad. I don't have solid plans for more, but I'm contemplating maybe another combat squad to (more so for additional weapon options) along with maybe a tech marine and perhaps a rhino. I'm very tempted to spring for the FW Mk6 armored models. But before any of that, I will be going back to complete my DW command squad and Belial. I have a habit of jumping around, but I need to force myself to do one at time. hehe.
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2747000
  • 3 months later...
Massive lack of updates for ages, I'm just lazy. A wet summer's day and a lack of surf prompted me to get the paints out today though, and I've cranked out a 3rd Typhoon (a la the previous two, so no need for pics) and a Dreadnought...
I know there are a few iffy bits, but I'm quite pleased considering an hour and a half previously it was grey plastic. In the last couple of months I've also more or less finished a Ravenwing melta squad, which means that the majority of my main two list variants at 1500 pts are now of a table top quality, which I find very satisfying. Hope you like what you see, and are there any ideas for a name for the scroll-work on the Dread? I won't be painting it on but I do have a 0.1mm pen which should do the trick!!
Cheers...
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2840833
As a fellow Unforgiven who hates painting, I know what you're going through. That being said, your models look awesome! Very cleanly done, and some very nice additions made as well. I like the fact that nothing you added on was over the top. Don't be afraid of painting bare heads. I've gone the lazy route of using tallarn flesh with an ogryn flesh wash to do mine, I'll add up some pictures later.
Adding the Ravenwing feather banners to a dreadnought? Consider that idea stolen! Sorry Brother skink. :P
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2841015
Skink, I think that your stuff looks very good and is coming along nicely. The Dreadnought looks very cool, interesting scheme for it. I also like the old Ravenwing bike banners, and after seeing that idea, I'm disappointed that I can't find my old ones now.
Don't know if you noticed or if it was intentional, but on the first pic, it looks like there is a seam that runs from the top of the arm down to the center where the plasma cannon is, and it looks like marble with what I'm assuming was a wash pooling on one side of it. Actually makes it look pretty neat, but you may want to trim it down around whatever that little targeter thing on the arm is.
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2841021
This is a very bada$$ Cyclone you got there!!! I really like what you've done with "exotic" conversions for the c/c weapons for your Termies! Keep it up (I know it takes discipline - especially in the summer :rolleyes:).
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2841160
Thanks for the comments guys, glad that people are liking them.
I'm afraid that I can't take credit for using the old RW banners, I was inspired by someone (I thought they were on the Fortress of the Unforgiven, but I can't find it now) using an old Kislev (sp?) horse banner as a standard for their DW captain. The RW feathers were but a short step from this. Bryan: I got the banners off eBay for not very much at all if you get desperate. The pooling is not intentional, I was simply rushing, so I'm grateful that you've pointed it out. The standard chime of "it's not that visible in real life" applies here, so as it is less noticeable on the table top I think I'll crack on with getting the rest of it past the primer stage before I come back to it.
Kovash: What would Devlan wash over Tallarn look like? I don't have any Ogryn, and am loathe to buy a new paint for two faces.
Semper: Thanks, I get lots of comments on the Cyclones! I think I prefer the standard pattern, but these were cheap as chips to make and, for a Heavy 2 missile launcher, are clearly WYSIWYG! My two squads of old DW and Belial are currently letting the side down, but I'll get there.
Cheers for the encouragement!
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2841666
If I had some Devlan Mud left I would test it out for you, but I let my friend borrow it and he proceeded to use it all. So until he orders more, I can't test it out for you.
Here's a picture of one of my sergeants with the Tallarn Flesh/Ogryn Flesh combo:
Did the best I could with my iPhone, I can't find the charger for my camera so no high quality pics. It looks fine to me, I'm curious as to what a Devlan Mud wash would look like.
Edit: fixed image
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2842829
Kovash: Thanks for the pic, the face looks really crisp. I'll have a crack soon and report back...
Ee: Please do, I hope they reap as much destruction as mine have! It should be very obvious how to fashion them, but if you have any queries/find a better way of doing it/discover any neat tricks then do let me know! Glad you're liking the army so far, thank you.
https://bolterandchainsword.com/topic/228688-wip-da-shots/#findComment-2843688
