What if Execution Force succeeded? (possible spoilers ahead)
With Horus dead, the Chaos force would split and fracture, each Legion going into their own sort of crusade of butchering, some directed at their enemy Loyal counterpart (e.g Iron Warriors vs Imperial Fists). The Loyalists and the Emperor would seize the initiative and strike back at the heretics driving them back into the Eye. The Loyalists would then conduct a war against the traitors slowly grinding them to nought and all the Loyal Primarchs go skipping in the Imperial Palace.
Chaos goes to plan B and another traitor Primarch takes over, probably Fulgrim due to his possession by a daemon. However, there would likely be mass infighting amongst the traitors.
The Sons of Horus would go nuts and probably launch all out attacks on their own on every major imperial target they could find in retribution, or worse turn to Abbadon for tactical leadership.
The World Eaters would become a loose cannon, even more so than usual and be a major force rampaging through the Imperium.
the Death Guard would probably split off from the traitors as Mortarion was only loyal to Horus and not even corrupted until the flight to Terra.
The Night Lords were already at war with the Imperium so they would have little reason to stop after Horus' death.
The World Bearers would continue Chaos' plan, Lorgar leading them, and keep fighting against the Imperium to continue their war against the Emperor. Then most likely run for the Eye of Terror if things turned bad for them to begin a long war against the Imperium.
The Emperor's Children would probably work with the World Bearers due to their leader. Most likely leading the Chaos attacks and try to create as many uprisings against the Imperium as they could.
The Thousand Sons would see the Heresy would not go the way they wanted and stay on the Planet of Sorcerers dealing with their own problems.
The Alpha Legion could either turn loyal again and fight against Chaos, i'm not sure exactly what they would do.
No idea what the Iron Warriors would do.
Each of them would most likely hunt down them one at a time and use the time they had to reorganise and regroup to launch massed counter attacks against the traitor legions. The Emperor would work to repair the damage Magnus had caused and get back to his plan, also possibly working to deal with Chaos.
Fulgrim or Logar would be my obvious choices. but with no Horus comes no talk of defection, so no laer blade being used agaisnt Ferrus meaning no broken brother hood, Also with Horus dead no Kabal to approach Alpharius to ask about turning renegade. which would also mean no black rage as Sanginius's legs wont get broken.
IF anything I think Peruabo would be the next likey choice. A master of warefare whos garrisoned troops could play and manipulate planetary tithes thus striking in complete suprise and mustering enough resources to start a real war, with the assitance of the already defected Night Haunter they could be the Real hammer & dagger in the night against the supple body of the imperium.
Nemesis is set 2 years after Istvaan V.
