nurglez Posted May 6, 2011 Share Posted May 6, 2011 Right, so, if a str 3 model with poison charges a t4 model, and has furious charge, does it get to reroll the to wound dice? Link to comment Share on other sites More sharing options...
JamesI Posted May 6, 2011 Share Posted May 6, 2011 I would say so as he is str 4 that round. Link to comment Share on other sites More sharing options...
Tanhausen Posted May 6, 2011 Share Posted May 6, 2011 IIRC, poison just means you wound on a fix number (2+, 4+ or whatever), regardless of toughness. FC means you get higher S (a waste in this case) and initiative. Why would you re-roll? Link to comment Share on other sites More sharing options...
JamesI Posted May 6, 2011 Share Posted May 6, 2011 If the attacker with a poisoned weapon has the strength equal to or greater than the targets toughness you get to reroll the wound roll. Link to comment Share on other sites More sharing options...
Dan VK Posted May 6, 2011 Share Posted May 6, 2011 Why would you re-roll? Under Poisoned weapons: "In addition, if the Strength of the wielder is the same or higher than the Toughness of the victim, the wielder must re-roll failed rolls to wound in close combat." BRB pg42 Link to comment Share on other sites More sharing options...
nurglez Posted May 6, 2011 Author Share Posted May 6, 2011 but my point is, do you use the unmodified str or the modified str to determine if you can reroll the wound dice. I thought yes at first, but then due to other things only using the unmodified stat, I wasn't so sure. Link to comment Share on other sites More sharing options...
Leonaides Posted May 6, 2011 Share Posted May 6, 2011 re-roll. At this point, the relevant stat is s, and s=4 due to fc. Dont get confused with things like halberds +2i, but a gk still being i4 for pursuing for example. Link to comment Share on other sites More sharing options...
Tanhausen Posted May 6, 2011 Share Posted May 6, 2011 The BRB has 42 pages? Really? :rolleyes: Thanks for the quote Dan VK In that case, yep, you do have S4 ... ergo you get to re-roll. Nice learning there... Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted May 8, 2011 Share Posted May 8, 2011 just remember thats close combat only, dont try to reroll your helfire shots. Link to comment Share on other sites More sharing options...
JamesI Posted May 8, 2011 Share Posted May 8, 2011 just remember thats close combat only, dont try to reroll your helfire shots. The FAQ also states that hellfire rounds are Strength 1. Link to comment Share on other sites More sharing options...
Grey Mage Posted May 8, 2011 Share Posted May 8, 2011 Still, its worth keeping in mind for the future. I also agree- use the strength they are striking at, not their base strength. Link to comment Share on other sites More sharing options...
