LRC Sponson Position
IMO the sponsons look better forward on a Crusader, also you could take into account that while rear mounted sponsons have a slightly wider field of fire, forward mounted sponsons get into range slightly quicker.
What it all comes down to is whether you are building the tank for competitive edge or whether it's to be a good looking centrepiece in your army.
If it's the latter then mount them where you think they look best.
Also good luck putting the sponsons together, I have that model and the metal hurricanes are a b&*$h :lol:
I agree with using the Front mount on it I do and never have ran into problems with dismounting marines from it However I would suggest picking up the Crusader/Redeemer sprue that way you can have less annoying plastic sponsoons and also have a set of sponsoons with the Flamestorms :lol:
Could you also put one lascannnon/hurricane bolter system/flamer at the front and one on the other side at the back? I guess it would be looking odd but you could catch both advantages somehow. Just an idea I came up with by reading your postings, won't do that with my LRs anyway..
I always put them at the front, slightly better range, and like someone said.. it's daft to get out of your tank and stand infront of two massive guns that are about to fire.
I personally think its daft to get out behind said guns and have to walk round in front of them...
Better that and use teh tank as cover than to risk getting hit by you're own surpressing fire. Its a reason why most RL helicopters and IFVs open up at the back/sides... the few that don't are your assault craft for beach landings. If the LRC had weapons mounted sensibly in a turret - then fine, but it has silly side sponsons which can only overlap fileds of fire if teh LRC has them mounted in the front....
@coopervisor: I also prefer having my sponsons at the back simply cause it looks thousand times better. Especially for the lascannons it wouldn't look fine if they were placed in the front, imo. But hey, I play a Dark Angels successor mostly for its unique look. So for advice on what is better on the battlefield I am not the right person to ask, I guess.
Personally I say go with forwards.
Consider 2" from the assault ramp at the front as your disembark distance.
With rear mounted guns, you've got a mediocre boost in size of deployment area.
If you move the guns forward however, the 2" from the rear hatch and the assault ramp will still slightly overlap and give you a much bigger area from which to jump out.
Front mounted guns also means it's harder to have all your exit points choked by enemy models...
Definitely forward. A heroic charge cut short by a quick shot to the head by your own tank is not very heroic.
Sergeant: Forward! For the Empe- Urgh!
Anonymous Marine: Sarge? Oh well, promotion opportunity. Charge forward, me- Uggh!
And thus began the Slaughter of Asteroid 9XQ48-M.
You can also use the sponson as cover so you're not disembarking into the fire that will almost definitely be headed towards your really big tank with nasty things inside.
I have one of each, and found that disembarking more than 5 Terminators from the front-mounted LRC was a chore. Tough to keep all those 40mm bases inside the 2" leeway area, as well as in coherency. I prefer the rear-mounted LRC, and find the extra 3" of range to be a non-factor in the front mount model. I'm always in range to fire something via PotMS.
I honestly think that when incorporated into the fluff, that the turrets are supposed to be rear mounted.
I get this thought because of the fact that the LR is a vehicle that is designed to get marines right into the fray of battle, right into business. I see this as the LR driving right up to the fighting, and then marines jumping out to get to the enemy as fast as possible, thus the idea of the assault ramp at the front of the vehicle. If the marines were supposed to get out behind the firing guns, then the ramp would be at the rear, ala rhino...
-kizzap
