robes on a librarian
puck
So I've got a terminator librarian model that I'm painting up in Deathwing colors and would like to paint the robes librarian blue. Should I use the same recipe as the armor, or since a robe is a more organic shape is there another recipe that would work better?
I've had this post up in the general PCA questions section and the tutorial requests section but have yet to receive a response.
What say the Unforgiven?
https://bolterandchainsword.com/topic/229450-robes-on-a-librarian/
I have also painted a deathwing librarian, and painted him in bleached bone armor with a blue robe and a blue psychic hood. For the robes, I started with Regal Blue and mixed a little Chaos Black in it, and painted the deepest crevices of the robes. Then I painted the rest with pure Regal Blue, leaving the darkest parts of the robes alone. Then layer the robe's edges with a wide layer of Enchanted Blue mixed with Regal Blue. Then paint a thin layer of pure Enchanted Blue. Finally, I highlighted the high parts and edges of the robes with Enchanted Blue mixed with Ice Blue for the final highlights. If you do it like this, it will be a very gradual transition between colors and look very natural, instead of the hard highlighting you usually see with armor. Hard edge highlighting works well for armor and hard surfaces, but the blending of colors is better suited for cloth. It just takes a bit of patience. Good luck.
As he plays guitar says, blending is the key. Personally, I wouldn't paint the robes blue if the armour is blue unless you can make it look distinct (different shade, perhaps). However, if you do, try to get hard, sharply contrasted highlights on the edge of the armour, perhaps going for a glossy finish (use gloss varnish to do this or use inks instead of washes). The robes can then be painted more subtly, blending up with lots of layers of slightly lighter colours to give a more organic, gradual finish. An laternative might be drybrushing to give a rougher texture to the cloth.
