scout sergeant powerfist?
Here is a link to two that I made for my sniper scouts: Scout Power Fists
The top one was made by trimming the top part of the arm from an older power fist to fit onto the model. The second one is the power armour power fist straight off of the sprue and glued to the scout body. The area where the power armour shoulder pad should go is the right size and shape of the current scout shoulder pad without any work. Hope this helps.
I used the Cadian command squad fist for my scout sergeant, except I cut the fist out (removed the angular "elbow" bit) and attached it about half way "down" the forearm gauntlet. Its the right scale for the scout so looks right and more importantly the rest of the arm is still the scout arm so the overall look is a still a Marine scout.
I'll try and get some (shoddy) pictures tomorrow to help explain.
This is how I did mine:
http://www.winterdyne.co.uk/maz/images/commissions/ultramarines1/scouts/squad_done1024.jpg
Used the sniper legs, and trimmed an old 2nd Edition PF just above the elbow. This is then pinned to the torso, which was trimmed away just under the pauldron. A bit of putty to fill in the 'sleeve' and a bit of guitar string to the sniper rifle's power pack and done. :-)
