Grand-Redemptor Ezkallon Posted May 16, 2011 Share Posted May 16, 2011 So I need a pin vise, but googling that didn't help at all. What I'd like to know is what brands are good, and what size drill bits to look for (in general). I'm in Canada, if that helps any. Thanks! -G-RE Link to comment https://bolterandchainsword.com/topic/229872-pin-vise-advice/ Share on other sites More sharing options...
Razblood Posted May 16, 2011 Share Posted May 16, 2011 For Bolters and pistols and such you'll want a 0.5mm - 1.0mm bit, for larger barreled guns (Heavy Bolter, Melta Weapons) 2.0mm is a good size. The GW pin vice is pretty good, but expensive ;) GW Canada site Drill bits are 0.5 mm I think of which you get 5. I also found this: Testors Pin Vice Testors products are quite well regarded from what I've seen. Not sure what size bits come with this. Google is your friend in these cases, but you may want to try searching for modelling tools in general, it'll probably lead you to what you are looking for. Anyway I hope I've been of assistance :angry: Link to comment https://bolterandchainsword.com/topic/229872-pin-vise-advice/#findComment-2759693 Share on other sites More sharing options...
Solid Zaku Posted May 16, 2011 Share Posted May 16, 2011 Ah Testors, you make equipment better than most...then balance it out with your paints :/ Link to comment https://bolterandchainsword.com/topic/229872-pin-vise-advice/#findComment-2759910 Share on other sites More sharing options...
