sons of malice paintscheme?
Yes.
Assemble your guys without their bolters or packs then spray them white...
once dry use blu-tac (or other sticky type putty) to mask off the quartered pattern...
(I would be tempted to mask one leg the opposite arm and the head leave the torso as the bolter will cover most of it anyway)
Then spray black and remove the putty after the spray has dried.
Now you just have to use some black and a brush to neaten up the dividing lines.
Attach the bolters and backpacks and paint the rest as normal.
I have used this technique on tanks and scouts to do camo, but it should work just fine for Sons.
Good Luck!
