ShinyRhino Posted May 21, 2011 Share Posted May 21, 2011 it's nto actually the difference in wording between Cleansing Flame and Dangerous Terrain that make it so you can't allocate their wounds, it's the difference between both of those, and the standard wounding rules. Standard wounding rules have you roll against a target's toughness value (or a flat value with poison, Ld with Neural Shredder, etc). The target of a shooting or melee attack is a UNIT, not a MODEL, unless that model is a single-model unit. Flame and DT tests roll to wound against enemy MODELS, and not against the unit. It's that compartmentalization of the unit's members that prevents the allocation of wounds. Even sniper units like Telion and the Vindicare target a specific UNIT, and then interrupt the flow of wound allocation with a special rule. Link to comment Share on other sites More sharing options...
BOBMAKENZIE Posted May 22, 2011 Share Posted May 22, 2011 just so long as we agree they are the same wording wise. You can look the words up yourself if you like but Each is a bunch of individuals. every is a group as a whole. Link to comment Share on other sites More sharing options...
