Viridian Posted May 20, 2011 Share Posted May 20, 2011 Hey everyone, just wonder what are the options for the land speeder in the Ravenwing Battleforce box set. I'm kinda nervous about buying one, mostly I want the flexibility to make Typhoon's instead of standard HB/AC right now. HB/AC is great but I want to fill out my fast slots with 3x Typhoon wondering if 2x Battleforce bot set's can get me ahead without being stuck with just HB/AC. -Sincerely Viridian Link to comment https://bolterandchainsword.com/topic/230162-ravenwing-battleforce/ Share on other sites More sharing options...
Cadorius Posted May 20, 2011 Share Posted May 20, 2011 Definitely no need to worry when it comes to Typhoons. You get 3 sets in one box. Link to comment https://bolterandchainsword.com/topic/230162-ravenwing-battleforce/#findComment-2764427 Share on other sites More sharing options...
timmytool Posted May 20, 2011 Share Posted May 20, 2011 the only thing it does not offer for DA is the underslung heavy flamer. one box has 3 sets of typhoon ML's one on each of the upgrade sprues it also has the kit to make 3 master of the ravenwing LS(pieces to make TL assultcannon and TL bolter) As for the speeder it is the old/first plastic land speeder sprues which did not have the underslung heavy flamer or assault cannon or the Typhoon missile launchers. The upgrade kits make up for the Typhoon missile launchers(x3) and underslung assault cannon(x3mounts x6assultcannons x3lights cus the mounts have 2 points)but not the heavy flamer. Nether the new or old landspeeder sprue have the underslung heavybolter/multi-melta or the passenger heavy flammer. (to my knowledge as I have only seen Googled sprues from the net for the new speeder) Link to comment https://bolterandchainsword.com/topic/230162-ravenwing-battleforce/#findComment-2764463 Share on other sites More sharing options...
ilnar Posted May 20, 2011 Share Posted May 20, 2011 Remember though, that you can only upgrade one speeder in a squad in the DA codex. :D One of the reasons I've started using C:SM for my mixed wing lists Link to comment https://bolterandchainsword.com/topic/230162-ravenwing-battleforce/#findComment-2765264 Share on other sites More sharing options...
EPK Posted May 21, 2011 Share Posted May 21, 2011 Remember though, that you can only upgrade one speeder in a squad in the DA codex. :teehee: One of the reasons I've started using C:SM for my mixed wing lists That is why the current trend (now that Typhoons have been updated) is to just run 2-3 separate LS Typhoons. I believe that is the OPs intention as he said "fill out" his fast slots. You may not have the durability of a squadron, but you now have the versatility to hit multiple targets that may be in completely different places on the board. One of the ideal load outs now, Typhoon with Multimelta, from the DA codex is also 35 points cheaper than C:SM equivalent. Link to comment https://bolterandchainsword.com/topic/230162-ravenwing-battleforce/#findComment-2765945 Share on other sites More sharing options...
