stormraven, servo skulls, shadow skies
Shyft
I'm tinkering with some experimental lists, and I was wondering:
You can disembark even after going flat out with the Stormraven, using the deep-strike rules. Servo Skulls reduce Deep Strike scatter by 1d6. So, if I drop guys out using Shadow Skies over a Servo Skull, do they scatter less?
Also, can I drop Dreadnoughts using Shadow Skies?
As far as I can see Yes and Yes. Your units will scatter 1d6 less but you will still take the dangerous test for scattering. Dreadnought it says "passenger" so yes you can drop your dreadnought.(Though if you roll a 1 on your dangerous terrain you'll be immobilized I think)
