Deathwing Command Squad
smellyfox
I was just wondering what peoples ideas where for making a Terminator standard bearer?
I only use banners spereingly in my army, they a reserved for special characters and company masters. Seargents etc have icons rather than banners.
Keeping this in mind would it be acceptable to mount the deathwing banner on the back of a terminator do you think? Or should I convert a PF?
I don't want to turn up at a tourney in the future to get told its not acceptable!
Cheers for any advise!
https://bolterandchainsword.com/topic/230207-deathwing-command-squad/
If you don't want to get a command sq just for the banner pole l used a thunder hammer minus the hammer top (the outstretched arm one) then from their add a paper banner with a carved sprue banner top would do. l used a command sq banner myself only cus l had one spare.
I too use the command squad banner. I drilled a hole through a closed hand powerfist, and stuck a brass rod through to give it a little more support. I then pinned then banner to the brass rod. The empty banner makes it easy to paint the DW standard on it, or if you suck at free-hand like me and have access to a quality color printer, print it out on a transfer sheet, and cut to fit the art work to place on the blank banner.
Some great ideas here thanks folks!
I pretty keen to work on my free hand skills, could anyone recommend a good tutoral?
Thanks!
dark to light is your friend here. i freehanded mine and it seemed to work out well
i started by sectioning of different sigments of colour(darkest shade of red at top and darkest shade of brown at the bottom) then building up from there
Model the standard all by itself on it's own slotta base and have either cherubs or servo skulls holding it up. That way you can place it close to any model that you wish to be a standard bearer and remove it if the local game rules don't allow it without having to create a standard bearer model specifically. Just an idea....
SG
SG
That is a sweet suggestion: consider it stolen!
What I do is magnetize...if I remember I'll post a pic tonight.
