greatcrusade08 Posted May 21, 2011 Share Posted May 21, 2011 just for my sanity, i want to cover the turbo pen he has a sniper rifle so it has S3 vs vehicles is that right? you then use 4D6 for pen at AP1.. with rending is it one D3 extra for each 6 you roll from the 4D6, or are you capped at a single D3 no matter how many 6's? so youd use 3+4D6 plus rending right thanks in advance Link to comment Share on other sites More sharing options...
Valkyrion Posted May 21, 2011 Share Posted May 21, 2011 I think rending per dice, like a Carnifex with rending claws was 2D6+2D3+S in 4th ed. edit: I remembered that rending was different in 4th. Sorry. p31 rule book; '...against vehicles an armour penetration roll of 6 allows a further D3 to be rolled with the result added to the score...' and 5th ed FAQ: Q: How does a monstrous creatureʼs 2D6 roll for armour penetration in close combat work if the creatureʼs Attacks have the Rending rule as well? (p31) A: The player gets to add a D3 to the total for each dice that comes up with a 6. So, if either of the two dice is a six, the total penetration roll will be 2D6+D3+S; if both were 6s, the total would be 12+2D3+S (which you donʼt need to roll anyway, as it is more than enough to penetrate the thickest armour!). The only sticking point is that a Vindicare isn't a monstrous creature, but I think the rules will apply. Link to comment Share on other sites More sharing options...
Chengar Qordath Posted May 21, 2011 Share Posted May 21, 2011 Per dice is also how rending worked with the Turbo-Penetrator in the previous codex; since the wording on the turbo-penetrator was not changed beyond improving it from 3d6 to 4d6, I would think it still works the same way. Link to comment Share on other sites More sharing options...
greatcrusade08 Posted May 21, 2011 Author Share Posted May 21, 2011 thanks guys.. mathematically it doesnt matter i suppose, rolling a double 6 (from the 4 dice) is 15 on the pen roll without adding rending or the other two dice.. it matters little however a potential 39 pen makes it the deadliest anti tank round going. Link to comment Share on other sites More sharing options...
Valkyrion Posted May 21, 2011 Share Posted May 21, 2011 And a potential 7 makes it (one of) the weakest. But you shouldn't have much problem penetrating with an average roll of 14 + 3 anyway. Rendings a bit odd on any multi dice penetration. If you roll a 6 you won't need the extra D3 and you only need the extra D3 if you don't roll a 6. I think there should be a rule similar to Instant Death - if you penetrate the targets armour by double you automatically destroy it. Anyway, thats anothe debate for another time. Link to comment Share on other sites More sharing options...
DarkGuard Posted May 21, 2011 Share Posted May 21, 2011 There will be instances when you rend and need the extra D3, for instance the other dice didn't roll high. There will, however, be times when you roll two rending hits, and therefore don't need the extra 2D3. Link to comment Share on other sites More sharing options...
shatter Posted May 21, 2011 Share Posted May 21, 2011 thanks guys.. mathematically it doesnt matter i suppose, rolling a double 6 (from the 4 dice) is 15 on the pen roll without adding rending or the other two dice.. it matters little however a potential 39 pen makes it the deadliest anti tank round going. Aye, minimum with 2 6s rolled is 3+6+6+1+1... which is quite a bit more than 14 and the rend or rends don't need to be rolled at all. Link to comment Share on other sites More sharing options...
