Greyrog Posted May 21, 2011 Share Posted May 21, 2011 Im Playing a Knights of blood Desent of angles Army im doing them closer to chaos. my marines are made form blood angels, dark angles ,black templar, chaos space marine and Khorne bits. I want to use the Gabriel Seth Rules for my HQ because I want to use the Khorne lord model as my Hq. but the rest of the army is DOA. I thought about drop poding him or putting him in a rhino but It seems that if he drop pods or is the only rhino on the field it would get destroyed turn one. I guess the question I need to know is if you only have 1 drop pod in your army does it have to come down turn one? can I hold it in reserve and roll for it starting turn two? I have kicked around the idea of running him in a stormraven with an assault squad. but I feel that Death company would be better in a storm raven and don't really have plans to ever run two Ravens. also would it be better to run him with a assault squad or a tooled up honour guard? Thanks Link to comment https://bolterandchainsword.com/topic/230245-seth-in-a-desent-of-angles-list/ Share on other sites More sharing options...
Cpt. Blood Donator Posted May 21, 2011 Share Posted May 21, 2011 Im Playing a Knights of blood Desent of angles Army im doing them closer to chaos. my marines are made form blood angels, dark angles ,black templar, chaos space marine and Khorne bits. I want to use the Gabriel Seth Rules for my HQ because I want to use the Khorne lord model as my Hq. but the rest of the army is DOA. I thought about drop poding him or putting him in a rhino but It seems that if he drop pods or is the only rhino on the field it would get destroyed turn one. I guess the question I need to know is if you only have 1 drop pod in your army does it have to come down turn one? can I hold it in reserve and roll for it starting turn two? I have kicked around the idea of running him in a stormraven with an assault squad. but I feel that Death company would be better in a storm raven and don't really have plans to ever run two Ravens. also would it be better to run him with a assault squad or a tooled up honour guard? Thanks It has to come in on turn 1. You could buy the death company a drop pod and drop that empty on turn 1, and then use RAS with drop pod and Seth. The death company comes in with the raven. Link to comment https://bolterandchainsword.com/topic/230245-seth-in-a-desent-of-angles-list/#findComment-2765828 Share on other sites More sharing options...
SamaNagol Posted May 21, 2011 Share Posted May 21, 2011 Seth can join a Death Company squad, AND he would then also benefit from the Chaplain's re-roll to hit on the charge if you don;t want to use the Whirlwind of Death rule. So just do that? Link to comment https://bolterandchainsword.com/topic/230245-seth-in-a-desent-of-angles-list/#findComment-2765866 Share on other sites More sharing options...
Greyrog Posted May 21, 2011 Author Share Posted May 21, 2011 Seth can join a Death Company squad, AND he would then also benefit from the Chaplain's re-roll to hit on the charge if you don;t want to use the Whirlwind of Death rule. So just do that? Ok so Seth a chaplin and 8 death company come down in a drop pod turn 1 this would be a hard unit to get rid of and could take a lot of fire. I might try this and see how it works. Should I arm the death company with bolters to take advantage of relentless? Link to comment https://bolterandchainsword.com/topic/230245-seth-in-a-desent-of-angles-list/#findComment-2765923 Share on other sites More sharing options...
Cpt. Blood Donator Posted May 21, 2011 Share Posted May 21, 2011 Seth can join a Death Company squad, AND he would then also benefit from the Chaplain's re-roll to hit on the charge if you don;t want to use the Whirlwind of Death rule. So just do that? Ok so Seth a chaplin and 8 death company come down in a drop pod turn 1 this would be a hard unit to get rid of and could take a lot of fire. I might try this and see how it works. Should I arm the death company with bolters to take advantage of relentless? As you'll be dropping in, yes. Link to comment https://bolterandchainsword.com/topic/230245-seth-in-a-desent-of-angles-list/#findComment-2765928 Share on other sites More sharing options...
shatter Posted May 21, 2011 Share Posted May 21, 2011 Aye, second pod or get him attached to a SR squad. Link to comment https://bolterandchainsword.com/topic/230245-seth-in-a-desent-of-angles-list/#findComment-2766117 Share on other sites More sharing options...
SamaNagol Posted May 21, 2011 Share Posted May 21, 2011 Yes, or you can just put him in the Stormraven with the Death Company if you want to guarantee the charge. Link to comment https://bolterandchainsword.com/topic/230245-seth-in-a-desent-of-angles-list/#findComment-2766308 Share on other sites More sharing options...
