Inaspin Posted May 25, 2011 Share Posted May 25, 2011 Quick question, cos I just started using the Librarian... According to the rule book a force weapon grants an additional psy power. Am I interpreting it correctley: you could power up the Librarian to strength 10 in the shooting phase and then kill the opponent outright with a sucessful force weapon psy check in the turn's assualt phase. On the same subject...are monstrous creatures able to use 2 psy powers each turn cos they can shoot twice? Link to comment https://bolterandchainsword.com/topic/230583-the-force/ Share on other sites More sharing options...
Red Fury Posted May 25, 2011 Share Posted May 25, 2011 No. and No. The "additional power" is the ability to use a psychic ability to insta-kill a multi-wound opponent. A standard Librarian that is allotted just 1 power per turn cannot use Sang Sword and then use the Force Sword ability in the same turn. If you had the epistolary upgrade, then you could. The MC rules grant no additional psychic abilities. Although some psychic powers are shooting powers they are not the same as firing a weapon. Psychic power =/= weapon. Link to comment https://bolterandchainsword.com/topic/230583-the-force/#findComment-2770711 Share on other sites More sharing options...
Cpt. Blood Donator Posted May 25, 2011 Share Posted May 25, 2011 No. and No. The "additional power" is the ability to use a psychic ability to insta-kill a multi-wound opponent. A standard Librarian that is allotted just 1 power per turn cannot use Sang Sword and then use the Force Sword ability in the same turn. If you had the epistolary upgrade, then you could. The MC rules grant no additional psychic abilities. Although some psychic powers are shooting powers they are not the same as firing a weapon. Psychic power =/= weapon. And in all fairness, you usually don't need sword and weapons power to instakill most things. The S10 is usually enough. Against needs I usually feel frisky and rely on a 5+ F.C wound followed by the forceweapon zap. Link to comment https://bolterandchainsword.com/topic/230583-the-force/#findComment-2770725 Share on other sites More sharing options...
vharing Posted May 25, 2011 Share Posted May 25, 2011 The only MC that I know of that can use two powers a turn is the Swarmlord and it states in his rules that he can use two. Link to comment https://bolterandchainsword.com/topic/230583-the-force/#findComment-2770820 Share on other sites More sharing options...
Demoulius Posted May 25, 2011 Share Posted May 25, 2011 the only MC's that arent immume to instant death but are higher then T5 are tyranid monstrous creatures and the wraith lord IIRC (dont know what the DE MC is for tougness and special rules...) and those tend to have the shadow of the warp/eldar special rule tallying around with them (as in psychic tests on 3D6's if your higher then 11 (or 12, not sure) on the dice you suffer perils...) other things like deamons are immume to it or wraithlords are T8 so youd need either furios charge or a higher strength (as in S10 from sanguine sword) in order to be able to hurt them to begin with (in which case again...you can only use the "zap" if your an epistolary....) and in those cases its wiser to use the reroll from UR to begin with as the odds of that working are higher still (and benefit the unit as well :cuss ) Link to comment https://bolterandchainsword.com/topic/230583-the-force/#findComment-2770866 Share on other sites More sharing options...
Cpt. Blood Donator Posted May 25, 2011 Share Posted May 25, 2011 the only MC's that arent immume to instant death but are higher then T5 are tyranid monstrous creatures and the wraith lord IIRC (dont know what the DE MC is for tougness and special rules...) and those tend to have the shadow of the warp/eldar special rule tallying around with them (as in psychic tests on 3D6's if your higher then 11 (or 12, not sure) on the dice you suffer perils...) other things like deamons are immume to it or wraithlords are T8 so youd need either furios charge or a higher strength (as in S10 from sanguine sword) in order to be able to hurt them to begin with (in which case again...you can only use the "zap" if your an epistolary....) and in those cases its wiser to use the reroll from UR to begin with as the odds of that working are higher still (and benefit the unit as well :) ) I'm pretty sure the wraithlord is the only unit in the game to actually have t8. Eeeem. A dread knight can also be instagibbed like this. Link to comment https://bolterandchainsword.com/topic/230583-the-force/#findComment-2770911 Share on other sites More sharing options...
JamesI Posted May 25, 2011 Share Posted May 25, 2011 The only MC that I know of that can use two powers a turn is the Swarmlord and it states in his rules that he can use two. Demon Princes with Mark of Tzeentch can. Lets try to keep the questions BA related, or we can move this thread somewhere else on the board. Link to comment https://bolterandchainsword.com/topic/230583-the-force/#findComment-2770925 Share on other sites More sharing options...
Inaspin Posted May 27, 2011 Author Share Posted May 27, 2011 Ta for all the replies...now I know :huh: Link to comment https://bolterandchainsword.com/topic/230583-the-force/#findComment-2772701 Share on other sites More sharing options...
Demoulius Posted May 29, 2011 Share Posted May 29, 2011 Ta for all the replies...now I know :) and knowing is half the battle :blink: (sorry couldnt resist) Link to comment https://bolterandchainsword.com/topic/230583-the-force/#findComment-2774647 Share on other sites More sharing options...
