chapter upgrade box
JasoX
Unfortunately you are too late to take advantage of the older price with more sprues which was definitely worth it. You used to get enough to make 10 robed marines (with bolters) and a butt load of extra bits for 20 USD. What you do not get is special weapons and bases.
Here is the old box's contents - http://www.bolterandchainsword.com/index.p...p;#entry1944005
Now it's half as much bits for 13.25 USD (so basically half as much as everything mentioned above but slightly more than half the price).
Is it still worth is? Only 5 robed marines now, but I'd still say it is, especially if you want robed marines and DA bits but don't need the weapons that the DA Vets box contains.
On a side note to the mods - we should probably update the list on the link above.
You've talked yourself into writing the list EPK :P. I'll (or Gilly or Chaplain Lucifer) will edit it in when completed.
Hooray! Waaait a minute...
Not a problem. I'll take a look at it. I'm guessing everything will just be halved.
Here is the update. I added "(attached to arm)" for bolters and "sheilds" for Deathwing heraldry just to make things more clear. I guess the two little vials are the "grenades"? I was never quite sure what they were.
Dark Angels Chapter Upgrade Sprue
MODELS
Arms - 5
Backpacks - 6
Backpack banners - 2
Bodies (robed) - 5
Heads (bare) - 1
Helmets (Dark Angel) - 2
Helmets (hooded) - 4
Shoulder pads (Dark Angel) - 10
Terminator legs - 1
Terminator shoulder pads - 3
Torsos - 5
Note: NO bases.
WEAPONS
Bolters (attached to arm) - 5
Bolt pistols (holstered) - 2
Combat blades - 2
Combat shields - 1
Deathwing assault cannons (w/ ammo feed) - 1
Deathwing power swords - 1
Deathwing storm bolters - 1
Grenades - 1
Power fists - 1
Power maces - 1
Power swords - 1
Storm shields - 1
MISC. BITS
Ammo pouches - 2
Belt hangers (censors, etc) - 5
Dark Angel icons - 7
Deathwing heraldry shields - 2
Helmet wings - 2
Open books - 1
Nice update EPK. I bought I think 3 of the old boxes when they were cheaper than a tactical box. They have come in so handy for a lot of conversion work on marines/termies/vehicles. I'm currently in the process of turning those power maces into thunder hammers instead of buying a whole new box or the bits themselves. The bits are also really useful for making sergeants or vets. The extra power swords/fists are great for it. I just wish they came with deathwing thunder hammers as that would just be an absolutely ridiculous bargain.
