CutThroatRazor Posted May 26, 2011 Share Posted May 26, 2011 I have a squad that I need to get apart and remodel. What can I do? I know superclean and brakefluid works to get the paint off but what can I do to get the glue to dissolve? Thanks for any help. *(The glue is Extreme Power CA [medium] from Hobby Lobby) Link to comment https://bolterandchainsword.com/topic/230683-how-do-i-get-models-apart-after-they-have-been-glued/ Share on other sites More sharing options...
somogyi Posted May 26, 2011 Share Posted May 26, 2011 I have a squad that I need to get apart and remodel. What can I do? I know superclean and brakefluid works to get the paint off but what can I do to get the glue to dissolve? Thanks for any help. *(The glue is Extreme Power CA [medium] from Hobby Lobby) Depends on what kind of glue you used. If you used supper glue you should be able to just pop the parts off. If you used plastic glue, liquid cement for plastic, or modeling cement it is hard because it basically fuses the parts together. If you used that kind of glue you just have to be real careful and pry it apart, but in my experience you end up breaking the model before it comes apart. Link to comment https://bolterandchainsword.com/topic/230683-how-do-i-get-models-apart-after-they-have-been-glued/#findComment-2772419 Share on other sites More sharing options...
CutThroatRazor Posted May 26, 2011 Author Share Posted May 26, 2011 I used super glue. I popped off all of the parts that I could but the heads, torso and legs are all being a real pain! Link to comment https://bolterandchainsword.com/topic/230683-how-do-i-get-models-apart-after-they-have-been-glued/#findComment-2772432 Share on other sites More sharing options...
chewielight Posted May 27, 2011 Share Posted May 27, 2011 You can put the model in the freezer and the bond with super glue becomes brittle so it shouldnt take too much to pop it out. I know this goes without saying but be careful trying to pry the parts off. I have seen (done) many a nasty cut trying to pry minis apart. Link to comment https://bolterandchainsword.com/topic/230683-how-do-i-get-models-apart-after-they-have-been-glued/#findComment-2772622 Share on other sites More sharing options...
Octavulg Posted May 27, 2011 Share Posted May 27, 2011 I find painting them as nicely as I can and then dropping them on the floor is a very reliable method. ;) The easiest way to separate the torsos from the legs is to twist them, usually. In regard to the heads...I find that if the heads don't want to come off, I'm very unlikely to be able to make them do so. Far easier to suck it up and paint them as they are. Link to comment https://bolterandchainsword.com/topic/230683-how-do-i-get-models-apart-after-they-have-been-glued/#findComment-2772636 Share on other sites More sharing options...
CutThroatRazor Posted May 27, 2011 Author Share Posted May 27, 2011 I find painting them as nicely as I can and then dropping them on the floor is a very reliable method. :P LOL :rolleyes: Link to comment https://bolterandchainsword.com/topic/230683-how-do-i-get-models-apart-after-they-have-been-glued/#findComment-2773240 Share on other sites More sharing options...
MagicMan Posted May 27, 2011 Share Posted May 27, 2011 With heads, if you can get a pair of thin pliers and apply pressure to the neck, or under the chin, you can usually make the helmets pop out. Just try to apply pressure to the neck join if you can, so you don't end up damaging the head itself. Link to comment https://bolterandchainsword.com/topic/230683-how-do-i-get-models-apart-after-they-have-been-glued/#findComment-2773449 Share on other sites More sharing options...
Manes Posted June 1, 2011 Share Posted June 1, 2011 I find painting them as nicely as I can and then dropping them on the floor is a very reliable method. :P I can vouch for this method :huh: Also try to wedge something thin but strong, like modelling knife between connecting parts. Link to comment https://bolterandchainsword.com/topic/230683-how-do-i-get-models-apart-after-they-have-been-glued/#findComment-2778384 Share on other sites More sharing options...
Olgerth Istaarn Posted June 1, 2011 Share Posted June 1, 2011 If the cement was used sparingly, you can pry most parts apart with careful wedging or twisting. Of course, there might be collateral damage to later greenstuff. If the cement was used liberally however, forget it. Two parts become fused together and unless you saw them apart with a jeweler saw, they are there to stay. Link to comment https://bolterandchainsword.com/topic/230683-how-do-i-get-models-apart-after-they-have-been-glued/#findComment-2778749 Share on other sites More sharing options...
Red Fury Posted June 1, 2011 Share Posted June 1, 2011 If the freezer trick doesn't work, then try giving them a 24 hour soak in purple power or simple green. Whenever I strip paint off of superglued minis, they come out of the bucket in pieces. Link to comment https://bolterandchainsword.com/topic/230683-how-do-i-get-models-apart-after-they-have-been-glued/#findComment-2778868 Share on other sites More sharing options...
