sp4rky Posted May 28, 2011 Share Posted May 28, 2011 I only just thought about it whilst assembling my new FineCast models... If I use the plastic glue, will it work? will the models melt into oblivion like the wicked witch of the west? I don't really want to test it on my brand new expensive models! thanks in advance :P Link to comment https://bolterandchainsword.com/topic/230782-finecast-and-plastic-glue/ Share on other sites More sharing options...
RebG Posted May 28, 2011 Share Posted May 28, 2011 As far as we've been told so far it's normal resin so no, you need superglue. Plastic glue (surprisingly) only works on plastic :D Edit: The GW site is saying superglue too Link to comment https://bolterandchainsword.com/topic/230782-finecast-and-plastic-glue/#findComment-2774157 Share on other sites More sharing options...
Olis Posted May 28, 2011 Share Posted May 28, 2011 Why not test it on some sprue? Link to comment https://bolterandchainsword.com/topic/230782-finecast-and-plastic-glue/#findComment-2774197 Share on other sites More sharing options...
sp4rky Posted May 28, 2011 Author Share Posted May 28, 2011 well that would just be too clever for me Olisredan :P. Superglue it is then, thank you! Link to comment https://bolterandchainsword.com/topic/230782-finecast-and-plastic-glue/#findComment-2774203 Share on other sites More sharing options...
Olis Posted May 28, 2011 Share Posted May 28, 2011 well that would just be too clever for me Olisredan :P. No offence intended. :P Link to comment https://bolterandchainsword.com/topic/230782-finecast-and-plastic-glue/#findComment-2774220 Share on other sites More sharing options...
Brother Tancred Posted May 28, 2011 Share Posted May 28, 2011 Definitely super glue, it was on Friday's blog post on GW site when assembling Skulltaker. Link to comment https://bolterandchainsword.com/topic/230782-finecast-and-plastic-glue/#findComment-2774225 Share on other sites More sharing options...
winterdyne Posted May 28, 2011 Share Posted May 28, 2011 No. You need superglue. Link to comment https://bolterandchainsword.com/topic/230782-finecast-and-plastic-glue/#findComment-2774309 Share on other sites More sharing options...
Rafen_2 Posted May 28, 2011 Share Posted May 28, 2011 As far as we've been told so far it's normal resin so no, you need superglue. Plastic glue (surprisingly) only works on plastic ;) Edit: The GW site is saying superglue too It's not normal resin just to say. It is a special compound that has been mixed with resin in order to make it less lethal and easier to use/covert. Link to comment https://bolterandchainsword.com/topic/230782-finecast-and-plastic-glue/#findComment-2774311 Share on other sites More sharing options...
chromedog Posted June 1, 2011 Share Posted June 1, 2011 Polystyrene cement only works on certain plastics - like the polystyrene that model kits (including GW's plastic kits). It DOES NOT work on resin, nor does it work on ABS (the resin-like grey plastic that PP uses for its plastic kits - as opposed to the resin they use for the larger pieces). You need a much more chemically aggressive solvent for ABS plastics (those solvents generally contain MEK, for example) and have the downside of destabilising resin (turning it into goo). Finecast IS a resin, it is a Polyurethane resin, that is similar to one used by many other miniature and garage kit makers use (FW use a different resin, but it is still a PU resin). Superglues or two part epoxy adhesives (araldite) are your options. Link to comment https://bolterandchainsword.com/topic/230782-finecast-and-plastic-glue/#findComment-2778312 Share on other sites More sharing options...
Rafen_2 Posted June 1, 2011 Share Posted June 1, 2011 Finecast IS a resin, it is a Polyurethane resin, that is similar to one used by many other miniature and garage kit makers use (FW use a different resin, but it is still a PU resin). Superglues or two part epoxy adhesives (araldite) are your options. Now what I said: It's not normal resin just to say. It is a special compound that has been mixed with resin in order to make it less lethal and easier to use/covert. Didn't say it wasn't resin just a different type from FW. Link to comment https://bolterandchainsword.com/topic/230782-finecast-and-plastic-glue/#findComment-2778968 Share on other sites More sharing options...
averykess Posted June 2, 2011 Share Posted June 2, 2011 Use superglue. Quick tip: Baking Soda can be used as a non-toxic accelerant. Put the glue on one side, lightly dust the other side with the baking soda. Link to comment https://bolterandchainsword.com/topic/230782-finecast-and-plastic-glue/#findComment-2779349 Share on other sites More sharing options...
