yowsaman Posted May 31, 2011 Share Posted May 31, 2011 hello fellow brothers, i was roaming the internet, looking for inspiration to make me a grey knight grand master wich stands out on the tabletop and aint your average terminator or draco model. I came across the kubika models on CMON and took a look at them and must say they really look great. now my questions are. do any of you have experience with these types of models? it also states that they are 40mm models. i dont really know how i can compare them with GW terminator models. ar they also 40mm? here are some pictures http://i661.photobucket.com/albums/uu339/yowsaman/kbk_kbk_kol_kol_101_000_01_large.jpg http://i661.photobucket.com/albums/uu339/yowsaman/kbk_kbk_kol_kol_107_000_01_large.jpg thanks for the advice guy's Link to comment https://bolterandchainsword.com/topic/230963-grey-knight-grand-master-model/ Share on other sites More sharing options...
RedemptionNL Posted May 31, 2011 Share Posted May 31, 2011 40k models are in the 'herioc 28mm' scale, so if these models are indeed 40mm, they would be noticably bigger. Unless they mean the size of the base, as a terminator sized base is 40mm. Edit, ah, the site lists it as both. Here's a quick comparison with a quick google image search of a GK Termie: http://i56.tinypic.com/mr8m0j.jpg Made the same base width. The angles aren't perfect, but it should at least give you an impression of the size difference. Link to comment https://bolterandchainsword.com/topic/230963-grey-knight-grand-master-model/#findComment-2776989 Share on other sites More sharing options...
henrywalker Posted May 31, 2011 Share Posted May 31, 2011 i cant seem to find the site. can you post a link? Link to comment https://bolterandchainsword.com/topic/230963-grey-knight-grand-master-model/#findComment-2777014 Share on other sites More sharing options...
RedemptionNL Posted May 31, 2011 Share Posted May 31, 2011 i cant seem to find the site. can you post a link? http://www.coolminiornot.com/shop/catalogs...kabuki&cat= Link to comment https://bolterandchainsword.com/topic/230963-grey-knight-grand-master-model/#findComment-2777016 Share on other sites More sharing options...
yowsaman Posted May 31, 2011 Author Share Posted May 31, 2011 thanks for the replay guy's. i guess you can kinda compare these models with the scibor models. they are also a bid larger then normal Gw terminator models. in my eye's perfect for a Grey knight grand master :mellow: just saw on there website that the shouderpads, helm, sword, and right leg all come seperatly. so some swapping of material should be doable i guess. maybe swap the shoulder pads with those of a grey knight terminator and also the helm and the sword. still wondering tho if i'm going to by it as the model is kinda expensive. :P greetz Link to comment https://bolterandchainsword.com/topic/230963-grey-knight-grand-master-model/#findComment-2777020 Share on other sites More sharing options...
gil galed Posted May 31, 2011 Share Posted May 31, 2011 Alternatively from the same site I thought this could be good. http://www.kabukimodels.com/index.php?go=produkt&id=42 Change the mace for a halberd and either keep the book or change. ~Gil :rolleyes: Link to comment https://bolterandchainsword.com/topic/230963-grey-knight-grand-master-model/#findComment-2777585 Share on other sites More sharing options...
