NightrawenII Posted December 11, 2011 Share Posted December 11, 2011 Because I dislike thread-jacking... :jaw: Having read everything posted up so far, I am very impressed. The only criticism I have at the moment, being limited on time, is that is very long. Said the author of Blades... ^_^ That's The Blades thank you :D Although I am not entirely sure what you mean... Is The Blades IA too( ;) ) long? I think it's too wordy in some places, namely the Origins, the Purge and maybe the Homeworld section could be written out with the less expenses in word count. Link to comment https://bolterandchainsword.com/topic/230997-ia-the-blades/page/2/#findComment-2941896 Share on other sites More sharing options...
Shinzaren Posted November 13, 2013 Author Share Posted November 13, 2013 Updated, though it appears my coding may have some issues. If anyone could assist me with getting my left and right sidebars back into position it would be appreciated! Otherwise, the whole thing has trimmed a little for wordiness. Thanks Link to comment https://bolterandchainsword.com/topic/230997-ia-the-blades/page/2/#findComment-3520829 Share on other sites More sharing options...
Ace Debonair Posted November 13, 2013 Share Posted November 13, 2013 I managed to fix my sidebars by copying the text into notepad, then deleting the whole lot from the article. Once you retype the code to set up the sidebars again it seemed to work alright, and then you can just copy the main body of the text back in. There's almost definitely an easier way to deal with stuff like that, but I'm an awkward dinosaur who cannot get the hang of new-fangled things. so that's the best I can do. Link to comment https://bolterandchainsword.com/topic/230997-ia-the-blades/page/2/#findComment-3520844 Share on other sites More sharing options...
Lysimachus Posted November 13, 2013 Share Posted November 13, 2013 Not sure if it's what Ace is suggesting, but I've found that if you write all of the coding out in the Word(or whatever) document and then paste it in with the BB Code switched off (top left button) it seems to work a lot better? Hope that helps! Link to comment https://bolterandchainsword.com/topic/230997-ia-the-blades/page/2/#findComment-3521166 Share on other sites More sharing options...
Ace Debonair Posted November 13, 2013 Share Posted November 13, 2013 See, I was suggesting the long-winded version of the same procedure. I knew there was a better one out there. Cheers Lysimachus! Link to comment https://bolterandchainsword.com/topic/230997-ia-the-blades/page/2/#findComment-3521190 Share on other sites More sharing options...
recon0321 Posted November 22, 2013 Share Posted November 22, 2013 Like the scheme Link to comment https://bolterandchainsword.com/topic/230997-ia-the-blades/page/2/#findComment-3528333 Share on other sites More sharing options...
Deffrolla Posted November 29, 2013 Share Posted November 29, 2013 If the Chapter doesn't trust it's vehicles then might it not have a similar mistrust of complex weapons such as bolters? Would this mistrust lead to some sort of belief that ultimately everything finally comes down to a marine and his blade? I'm just a bit worried that if you're Chapter mistrusts machines that might fail then surely it would eventually come to mistrust all machines (vehicles, ships, weapons, sliding doors, coffee percolators and power armour, for instance?) If you are going to have fear of mechanical failure then you might need to explain why it only relates to one facet of their existence. In my opinion this is the big problem when you give them beliefs and attitudes in order to explain why you don't want them to have something a Chapter would normally have, such as a large number of vehicles). Just my own thoughts. I worry about this sort of thing all the time. Link to comment https://bolterandchainsword.com/topic/230997-ia-the-blades/page/2/#findComment-3533884 Share on other sites More sharing options...
Shinzaren Posted December 2, 2013 Author Share Posted December 2, 2013 It's not so much that they believe the machine will fail, they just prefer to trust in strength of flesh. They prefer to earn their kills face-to-face, and they see vehicles as being too distant, too detached from the fight to be a real kill. The same applies to the Techmarines. They let their machines fight for them, instead of doing it themselves, face-to-face. It's not that they believe their machines could fail at any moment, they just vastly prefer to triumph on their own strength. They don't see their power armor or bolter as a machine, simply an extension of themselves. Link to comment https://bolterandchainsword.com/topic/230997-ia-the-blades/page/2/#findComment-3535626 Share on other sites More sharing options...
Shinzaren Posted December 6, 2013 Author Share Posted December 6, 2013 Woot! Got the formatting back under control! Finally got my headers and my sidebars set back up. Should be much easier to read. Thanks for all the help! Link to comment https://bolterandchainsword.com/topic/230997-ia-the-blades/page/2/#findComment-3538959 Share on other sites More sharing options...
