toaae Posted June 2, 2011 Share Posted June 2, 2011 Now, on the can of my spray primer, it says "Do not spray at very low or high temperatures..." Question is, what temperatures are those? I live in Arizona, and today is a "mild" 94 degrees Fahrenheit . Might be the best day for spraying for a while. As long as I can find a shady spot, will I be fine, or should I just wait till night when it's going to be in the high 60s? Link to comment https://bolterandchainsword.com/topic/231173-spray-primers-and-temperatures/ Share on other sites More sharing options...
Hellrender Posted June 5, 2011 Share Posted June 5, 2011 i think it's chamber temperatures they mean. So roughly 15-25 degrees celcius (59-77 fahrenheit) But i did it with a GW primer, in a hot summer in the shadow aswell (29 degrees Celcius: 89 fahrenheit) Good luck edit: If i were you i would do it idd in the evening or early morning, is your best shot. Link to comment https://bolterandchainsword.com/topic/231173-spray-primers-and-temperatures/#findComment-2782585 Share on other sites More sharing options...
